If you use fine and coarse controls then one will always be in the wrong position. Use larger knobs instead.
Higher output current will cause a heat problem in the output and driver transistors. The improved version of this project already uses two output transistors to share the heat produced at 3A. Use a huge heatsink and a fan for 4A output. Change R7 to be 0.35 ohms/10W.
A 24VAC transformer is too low for this project to produce 30VDC output at 3A or 4A but the original TL081 opamps will have a voltage too high for them if the transformer voltage is increased. The improved version of this project uses TLE2141 opamps rated at a supply of 44V and a 28VAC or 30VAC transformer.
A transformer rated at 24V/4A has a limit of 24V x 3A= 72VA. But here the 24V is rectified to produce a peak voltage of 34V. Then if the load on this project is 3A the transformer produces 34V x 3A= 102VA. It must be rated for 102VA/24V= 4.25A. If the output of this project is 4A then the transformer must be rated for 5.7A.
thank you so much for your reply sir. :wub:
forget about using hi amp switching power supply instead of transformer. it was just a Curiosity question.
but about increasing the output amperes as you said for taking 4A from output i should change my transformer with 24v 5.7A.
so if i use 24v 4A transformer then how much amperes i can take from output?
cooling 2N3055 is not a problem. best heat sink and turbo fan used for that.
each 2N3055 can handle how much amperes in best cooling situation ?
in Chinese power supplies coarse and fine works well. they use same opamp and other parts for that.
volumes are :
Voltage Coarse : 50K - Voltage Fine : 5K
Current Coarse : 10K - Current Fine : 1K
before i asking my questions here i decided to use larger knobs as you said. but fine volume works better.
*i just completed the rear panel laser cutting file Designed with extreme accuracy.
so if anyone use the box just like mine then he/she can use this files without any changes.
but of course you can change it as you like.
the front panel will be done soon.
ebay link for used parts will be placed here.
