Martaine2005
- May 12, 2015
- 5,299
- Joined
- May 12, 2015
- Messages
- 5,299
Hello forum,
As the title suggests, I’m having issues with noise.
One wire in particular on the breadboard which connects both sides Negatives together acts as an antenna.
The other noise issues are (I believe) low frequency oscillations from the DFPlayer while playing.
The Arduino has a higher frequency oscillation and when the neopixels flash, there’s a distinct clicking at the same time.
I’m powering the Arduino with my bench PSU with 8V. I put an LM7805 on the breadboards power lines for the DFPlayer and neopixels (one strip of 8).
I’ve added a 1000uF and 100nF to the power lines.
I’ve also added 100nF as close as possible to the DFPlayer VCC and GND.
I’ve tried several bench PSUs too with same results.
I realise that breadboards can be noisy but I’m hoping that someone will have had similar results and have a solution.
Google results say adding a series 1K resistor on the DFPlayer TX to Arduino RX fixes it . It doesn’t.
Others say a resistor divider (470 & 1K) works. It doesn’t.
Where else can I filter?
Thanks Martin
Thanks Martin
