0-30V Stabilized Power Supply
Status
Not open for further replies.
redwire
Nov 10, 2007
244
We seem to have lost the extensive discussion on this power supply topic.    I attached what I believe is the latest version.
NOTE the parts list included in the attached zip file is REV 5 dated 12/13/13  and  covers the next 125 pages of this tread.
0-30V.zip
  • 0-30V.zip
PicMaster
Feb 18, 2009
90
Thanks Red wire, I did look for this the other might and wondered what happened to it,
Does anyboady have the version for the OPA445 op-amp they have come back in stock at RS and ordered 10 of them so that I can continue with my version.
Not sure if the above will work the same ?
audioguru2
Apr 6, 2004
12,026
Hi PicMaster,
The OPA445 high voltage opamp will not work in the latest modification.
I didn't keep a schematic for the project with the OPA445 opamps because it was nearly the same as the original except for a couple of corrections. Here is the parts list for it:
EDIT: Dec 13, 2013.
1) The MC34071 is not available anymore in a through holes package.
2) The value and size of R22 was changed.
3) The value of R17 was changed.
4) The 10V zener diode was added.
Here is the latest parts list:
redwire
Nov 10, 2007
244
Audioguru,  do you have a copy of the last parts list using the alternate chips.  I seem to remember some of revisions were in red.
EDIT:  The first post contains REV 5 in the zip file.  Audioguru's post directly above this also contains the same update.  No need to read the next 125 pages except for fun
redwire
Nov 10, 2007
244
Thanks,  Now we have a sketch and some parts.  We can continue the discussion.
limbo243
Aug 5, 2009
8
Hy Guys!
Okay - after 1 damaged Zener and 2 damaged power transistors my power supply is now finished.
My experience:
- I used the MC34072 oamps with max.44V instead of the MC34071. With the MC34072 I was not able to do the offset compensation. So the current limiting became a problem. ( When I turned the current limiting to minimum, it stopped limiting the current and damaged the power transistors with 24A  output >:( ). So I used a 68Ohm resistor for R17 and all worked perfectly.
- I used a 2x30V - 230VA Transformer with 32.47VAC without load. The problem is the voltage without load of about 45.91VDC  -  too much for the oamp. So I decided to use D15 in my shematics.
In practice, the max voltage is about 44.1V so it will also work without D15.
Here are pictures of my working Power Supply, my shematics with the (hopefully...) correctly bill of materials for my shematics.
I decided to give you my bill of materials because there are a view mistakes and missing parts in the existing list.
Sorry for my bad english - hope everyone can understand me  :-[
means Markus
PS: More pictures in my next reply
Update: After a view tests at maximum output (30V 3A) I saw that D15 (10V Zener) in my schematic only allows an max output of about 24V at 3A. Or about 2.7A at 30V...
So I decided to throw D15 away and replaced it with a peace of wire. Now I am able to get 30V with 3A.
If someone has the same problem as I (The rectifier voltage is to high for the oamps with 44V) you can use D15 which should have only as much voltage as you need to get under the 44V. The voltage in my circuit is about 39.6V - 44V and nothing is damaged.
billofmaterials_V1_2.txt
  • billofmaterials_V1_2.txt
audioguru2
Apr 6, 2004
12,026
Hi Limbo,
Your power supply looks good.
I think the tiny 2N2219 Q2 driver transistor will melt if the output is shorted and the gain of the 2N3055 transistors is low. It will try to dissipate more than 3w which it cannot do even with a clip-on heatsink. A BD139 real power transistor should be used with a medium size heatsink.
I do not understand why the current regulation failed when it was turned down.
Since you reduced the unregulated positive supply by 5.6V with a zener diode can your project supply +30V at 3A without ripple?
limbo243
Aug 5, 2009
8
Hi audioguru!
Thank you  :D
The schematic is for simulation only. I added a small statement in the schematic: "For parts value see bill of materials". There you can see that I used a BD139 for Q2. In LTspice IV there is no BD139 in the database  ::)
I also don't know why the current limiting failed by min current. I was not able to find a mistake in my circuit. I decided to say it is because of the oamp offset  :p
I have no oscilloscope to see if there is a ripple by 30V at 3A. I only have the small multimeter which shows 30V and 3A. But if I get the chance for an oscilloscope I'll post a picture.
Do anyone have a 10Ohm 90W resistor for testing the power supply at maximum?  ;)
by limbo
bohko
Jul 13, 2009
5
Hi!
I would like to add to that circuit fine tuning for voltage and current. So i am asking where to put it on that circuit on first post?
My minimum output is 40mV not 0V and i cannot correct it with RV1 it has no effect.
Did i do something wrong or is it normal to get 40mV?
TNX in advance
Bye
audioguru2
Apr 6, 2004
12,026
Hi!
TNX in advance
Bye
You can add fine-tuning pots in series with the coarse adjustment pots but they will be always set to the wrong position.
If you made the latest circuit with MC34071 or TLE2141 opamps then RV1 adjusts the 0V output to 0V if your voltage adjustment pot can give a 0V output.
The output capacitor C7 makes the output positive without a load if it is an electrolytic type. A film capacitor will not.
dracu_n_dulap
Aug 11, 2009
21
hello. ;D
could you please tell me if there are any other equivalents to opamps used in the final version of the schematic? because i could not find tle2141 or mc34071
thanks
audioguru2
Apr 6, 2004
12,026
hello. ;D
thanks
The opamps chosen are sold everywhere in the civilized world. Maybe not on your different planet.
Digikey in North America and Farnell in many other countries sell the popular opamps.
There are many newer opamps that can also work.
Where are you??
gogo2520
Aug 14, 2005
495
Heres the link for the mc34071ap
http://parts.digikey.com/1/parts/462688-ic-opamp-sgl-supply-4-5mhz-8dip-mc34071ap.html
                      gogo
audioguru2
Apr 6, 2004
12,026
You do not need to buy 100 MC34071A opamps at Digikey. They have many of them for a single quantity purchase. They have ordinary ones and "A" premium ones.
dracu_n_dulap
Aug 11, 2009
21
Not another planet, just another continent, europe. From romania. To be honest i still have two places to ask for the opamps, but i asked for epuivalents to have a better chance at finding one of them and finnishing the psu, or even better ones, i mean some that have a higher max voltage for a better safety margin.
audioguru2
Apr 6, 2004
12,026
Hi Dracu,
Farnell have offices in many countries including Romania. They have hundreds of both opamps in stock in Romania. Go to www.farnell.com .
I buy electronic parts from their office in Canada.
Status
