0-30V stabilized power supply: construction problem.
sanket bhalsing
HI SIR...
I have to face following problem
1) The output voltage does not varry.
2) Final output voltage is 7-8V.
3) LED ON
4) Current also not varry
PLZ tell me solution ......
audioguru2
Apr 6, 2004
12,026
sanket bhalsing said:
On the original circuit:
1) The output voltage does not vary.
3) LED ON
4) Current also not vary.
Please post the answers to these DC voltage measurements:
1) What is the voltage at the output of U1? It should always be about +11.2V.
2) When the voltage pot P1 is turned from zero to maximum what is the voltage at the input pin3 of U2? It should change from 0V to about +11.2V.
3) When the voltage pot is at zero what is the voltage at the output pin6 of U2? It should be about -4V to +1V when the project has no load.
4) With the voltage pot at zero what is the voltage at the emitter of the driver transistor Q2? it should be about +0.5V when the project has no load.
5) With the current pot P2 at zero what is the voltage at the output pin6 of U3? It should be about +30V.
