12v 3000w inverter repair help
Stockleys1
Jun 19, 2019
Hi all. First time post for meI’m after some helpI am trying to repair a high frequency 3000w inverter.It worked great for 3 weeks when I got it (after replacing 2 IGBT’s)But then they blew and many more replacementsI bought a new spwm board from the manufacturer and a complete new set of IGBT’s along with their associated resistors and diode.Installed. And nothing. ABout 10 seconds in and one of the h bridge drivers exploded.So I ordered an EGS002 board from amazon. All pinouts exactly the same. Same chips as the spwm from the manufacturer only a third the price.I have installed this and tested all components around it including the IGBT’s. They are all good.The IGBT’s are getting a steady 390vdc source. The spwm getting a steady 5v and 12vBut I can’t get an output. I can hear the transformers buzz for 3 seconds then stop I get a blip of up to 8vac at the output. The spwm board flashes out the code for under voltage and over voltage. Where do I go from here? I don’t own a scope. Only a ddm.
I have checked and re check all components and solder joints.  But as I don’t own a scope, I can’t think what else to do.Thanks in advance
HarryA1
Mar 4, 2009
481
Without a circuit diagram it is very difficult to help you.  You can find numerous videos on youtube.com related to "EGS002 "   that maybe helpful. Good luck.
Looks like I was born under the sign  -V  (I talk to much?)
Stockleys1
Jun 19, 2019
I got myself a usb scope.
I found that the egs002 wasn’t giving the correct wave.  On outputs 1 and 2.   And output 3 was a constant 6v.  Not a wave at all.    Got another egs002 (before getting the scope). And that had one dead output.
Attatched is a schematic for the egs002.   And the h bridge.  Which although not for my inverter, is identical
tagjags
Jan 3, 2023
for whoever reads this can be useful,took me a while to figure out
The EGS002  Will ONLY produce waves for more than 3 seconds IF...
1»»»»»  pin 1 (over current)  must see LESS than 0.5 volts DC  (2  blinks of the egs002 led  if not...);
 15»»»»»  pin  15  (output voltage feedback signal) MUST see between  2.75 to 3.15 Volts DC;   set the little blue pot. to  3.0 Volts to test(3  blinks if over 3.15   OR 4 blinks if under 2.75 V)
  16»»»»  pin  16 (over temp) must see  LESS than 4.3 volts (5 blinks if over 4.3 vdc)
These are the ICs FACTORY values ,and I  confirmed them myself on my own inverter builds
Not ONE youtube channel teaches these things,is it on purpose? i should start my own...
leverperfect
Jan 13, 2023
4
 15»»»»»  pin  15  (output voltage feedback signal) MUST see between  2.75 to 3.15 Volts DC;   set the little blue pot. to  3.0 Volts to test(3  blinks if over 3.15   OR 4 blinks if under 2.75 V) basket random
Many thanks, It's useful for me.
toniamatii matiia
Jul 30, 2024
[SIZE=10pt]Payvantage has been fantastic. The no-credit approval process was quick and easy. I didn't have to worry about my credit score. I got the latest iPhone, and the payment plan is very reasonable. The whole experience was smooth and enjoyable. Highly recommend![/SIZE]
