12V-6V stepdown circuit wanted
David
I'm wanting to run a 6V cordless drill directly from a car cigarette lighter
socket. (Batteries have had it but it would be convenient to use in car.)
Can anyone suggest a suitable circuit?
K
KLR
for what its worth, my mobile auto-electrician has a 7.2v makita
rechargable drill that he modified to run direct from a car lighter
socket (12vdc) without any form of voltage reduction (other than the
resistance in the 4metre of .75mm square fig 8 that was used to
connect to the lighter plug). I did ask of this setup, as I was
concerned about the possible over-voltage issues and he said that the
drill had been working like this for many years on a daily basis with
his trade without any problems.
(He did get sick of flat batteries all the time with the original
setup)
I think its worth a try using such a distance of fig 8 cable - the
voltage drop in the cable is obviously enough.
David
Thanks Clifford . . I've already replaced the batteries - the drill is
20yrs old) - and I have others. In my campervan a drill would be handy at
times when I'm in the bush. I just don't like weasting things! I might give
the direct connection a try.
David
David
Thanks Ken,
I'll give it a try . . all I can do is burn the motor out, but at >20 years,
I guess it doesn't owe me much.
David
K
KLR
Thanks Ken,
David
Try a few metres of that cord - measure the voltage at the drill -
when drill motor is running, and let us know the voltage there - Im
curious as to the drop. I think you will find that this will provide
a pretty good voltage drop if you use a few metres.
F
FruitLoop
You of course could calculate this a little .
Find the running current of the 6 volt motor . Use a multimeter , hopefully
its not over 10A
Then find the resistance of the wire .Easily obtainable
Apply Ohms law V=IR
Maybe allow a 20 percent over voltage max to help with peak loads
Rheilly Phoull
One day FruitLoop got dressed and committed to text
hopefully its not over 10A
Apply Ohms law V=IR
OTOH is it wise to assume that the motor was indeed rated 7.2v ??
As said before many will run on a few more volts and likely have a little
more power. Particularly with older ones.
F
FruitLoop
Its a balance between reliability and power output verses duty cycle and
longtivity
