12v receptacle
Electric-T
Jun 4, 2017
212
Ill just jump right to the question. Is there a good reason no one uses a standard double prong receptacle with 12v applications? The only standard receptacle that i know is used for 12v is a cigarette lighter in a car. Or atleast it looks like one. Havent we moved on to a more standard looking receptacle yet? Could a 12v circuit be wired to a double prong receptacle?
kellys_eye
Jun 25, 2010
6,512
Polarisation basically. To allow a double-pronged connector you have to ensure it can only be inserted one way or fit some 'steering' device (a bridge rectifier will do it) to prevent misconnection.
But a BR means additional cost and power losses so it isn't done.
Electric-T
Jun 4, 2017
212
I feel like if something was manufactured with one prong positioned 90° relative to the other that would prevent misconnection. But in this instance the wires would be connected strait to the prongs
Externet
Aug 24, 2009
943
Minder
Apr 24, 2015
3,561
If needing simple polarized 2 pin connectors that are high current, the RC suppliers have them, there is a small selection of different types, the XT60 is a popular one.
M.
Alec_t
Jul 7, 2015
3,817
Indeed. But then it wouldn't fit a standard 2-prong receptacle, which is what your question is about.
Minder
Apr 24, 2015
3,561
The OP did not mention wall mount.
You can get RV/Marine panel mount outlets.
M.
Electric-T
Jun 4, 2017
212
This is really just a discussion at this point. If i find a good one i may use it on one of my upcoming renewable energy projects
Tha fios agaibh
Aug 11, 2014
2,253
Yes, because Nema design specifically rates receptacle outlets for current, voltage, and system configuration. So, No you can't legally (or ethically) use a 120vac outlet for 12vdc.
Externet made an excellent point. People will plug in anything that will fit into the receptacle and create a potential hazard.
The main reason DC is rarely wired to receptacle outlets is because most appliances are AC. If they are DC, use a receptacle that matches the plug used on the appliance. This is usually the cigarette lighter type.
Electric-T
Jun 4, 2017
212
Well maybe one day someone will create a more attractive looking receptacle. Just thought id bring it up
Irv
Jun 7, 2017
112
It's not really about attractiveness, it's about safety and reliability. Any kid will find a coin which fits into a cig. outlet in less than 10 seconds.
And having to wiggle and twist plugs to make a good, reliable contact is often a problem, as well. Not much bother if all you want is to light a cigarette, but not so good if you want to plug in an inverter or something. So, I would have to agree that the existing outlets are far from ideal.
Electric-T
Jun 4, 2017
212
I like the look of those "double barrel" plug that are usually on a dc power supply. Its a secure connection and they seem to be long lasting with getting too damaged over the years.
