12V to 230(400)V without transformer
Status
Not open for further replies.
pidja105
Oct 16, 2015
106
I am building my solar power plant for power company, but I must step up 12V to 230V(400V) three phase 150KW, how I can do that without big transformer plant?
If you are assigned that project, and you are coming here asking us that question, you are in way over your head. What are your qualifications? If you do not have a degree in power engineering, they hired the wrong person.
Sunnysky
Jul 15, 2016
577
150kW @12V is 12,500 AMPs plus efficiency losses.
Nice try
You would start with a 450Vdc PV array then use synchronous tri-phase bipolar bridge switching with a pseudo-sine wave.
A solution for 1% of this power in single phase split 240Vac voltages looks like this.
https://www.littleboxchallenge.com/pdf/finalists/56568-Tech.pdf
The magnetics are small due to the storage energy required is only a cycle at high frequency , rather than a cycle at 50 Hz. But the switching is shared by sequential devices to simulate a better sine wave.
The schematic is simplified and does not show gate pulse generation.
At some point the cost of electronic inverters needs step down transformers to transfer MW power levels so inversion is done at higher voltage where IGBT's work well. See Mitsubishi for examples
14,487
agreed,
you shouldn't be doing this ... the company should be employing an experienced EE
Thread closed
Status
