2-10v or 4-20 dimming of 120v light bulb
Scott McDonald
Dec 21, 2014
Good morning, working on a project where I need to demonstrate a modulating temperature controller, using a 100w bulb as a heat source. I'm looking for device that will take a 2-10v or 4-20 mA signal from my controller and vary current to the bulb... Any ideas?
Thanks!
Arouse1973
Adam
Dec 18, 2013
5,178
What about an automatic light dimmer using an LED and LDR. The light dimmer circuit is fairly simple so instead of using a POT which you turn to increase the brightness you control the current through the LED. So when the irradiance on the LDR increases as the LED gets brighter then this changes the brightness of the bulb. In your application it would be the 2-10Volts which does this by increasing the current through the LED. And obviously works the other way also which would reduce the brightness as the input voltage fell.
Adam
KrisBlueNZ
Sadly passed away in 2015
Nov 28, 2011
8,393
Is the bulb running from AC or DC? What voltage?
hevans1944
Hop - AC8NS
Jun 21, 2012
4,986
Do you want to build something from components, or buy off-the-shelf? This company offers a wide variety of solutions, one example at this link.
Please provide more specifications: Is this a 115 V AC 100 watt incandescent lamp you are using as a heater? How will you sense the temperature you intend to control? What range of temperatures? How much resolution and accuracy do you need for heater control? There are other considerations.
JWHassler
Dec 22, 2014
86
Thanks!
Here's a pretty-good description of what's available.
Are you doing your own current modulation scheme, or simply asking for a power-percentage?
