5v - 2A power supply causing damage
14,317
The multimeter read the red wire is positive
What is the voltage at the micro USB connector with no load connected? Sometimes the output voltage of a not well designed power supply may be much higher than the nominal value when no load is connected. If you then connect this supply to a load, the output voltage will drop to the nominal value but the initial value being too hihj may already have caused havoc.
Fractus
Dec 31, 2020
18
5.37v
14,317
That is reasonable and no cause for concern.
14,317
Yes I did as per my photo post #15
It is getting confusing: the image in post #15 shows a white wire, not a black one.
@Fractus : help us sort this out:
  • How many wires are in that cable from the power supply?
  • What are the colors of these cables?
  • How did you connect the cables to the micro USB plug?
  • If there are more than 2 wires in the cable, have you swapped any of them?
  • Which measurements have you made and what were the results?
Please give us a comprehensive and concise explanation. It is hard to follow along when information comes piecewise and partly contradictory.
Fractus
Dec 31, 2020
18
1. There are two wires from the power supply - see post #15 (white wire replaces black I presume......please note I'm new to electronics)
2. The only colours from power supply are red and white.
3. Connection of cable to micro USB see post #15.
4. Cannot understand your comment on measurements !!!
Thanks!!!
