ac to dc converter with speed control
hoolko
Mar 14, 2013
14
can anyone help me? ive attached a picture....this is an ac to dc converter with speed control for a dc motor...it came with no instructions and ive never seen one like this....do I wire my motor to the armature or excitation? thanks,Nick
shrtrnd
Jan 15, 2010
3,903
It might help if we knew what 'dc motor' you plan to use.
hoolko
Mar 14, 2013
14
thank you kindly....it is 17 pound high torque....90vdc....1/4 hp....2.9 amp....i can attach pic if needed...thank you for your time very much,Nick
brevor
Apr 9, 2013
87
Since your motor has only 2 wires they should connect to the armature.
jpanhalt
Nov 12, 2013
426
How many wires to the motor? If only two, then they go to the armature terminals. If there is a separate ground wire, it goes to ground.
The two wires of a permanent magnet motor will go to the armature connections. A shunt-wound motor may have just 2 wires, which go to the armature. If the field of a shunt wound motor is accessible, then the field wires goes to the field/excitation. The two wires to an AC/DC motor goes to the armature.
Here is a manual from a motor controller for shunt, PM, and AC/DC series motors: http://www.kbelectronics.com/manuals/kbic_manual.pdf
John
hoolko
Mar 14, 2013
14
ok....im advised to connect my motor in 2 different ways.....any other input from members? thanks, Nick
thank you so much John and brevor....i really appreciate your time and effort....sincerely, Nick
jpanhalt
Nov 12, 2013
426
What other advice? Both brevor and I gave the same advice, I think. I was a little more wordy. That's why it took me a minute longer. ;)
John
hoolko
Mar 14, 2013
14
ok, i just connected to the armature only and the speed control does not work.. the motor is running full at the 1750 rpm rating.....any other suggestions? ive messaged the seller i wish to return this item as there seems no simple hookup thanks everyone, Nick
duke37
Jan 9, 2011
5,364
You had the same advice from brevor and jpanhalt.
I also gave the same information in your duplicate thread.
There is a minimum speed control, have you set this correctly?
