Can an audio amplifier be used to transmit or receive radio signals?
ofosot69
Oct 31, 2024
9
Is it possible to make an audio amplifier transmit radio signals when connected to its output with a ferrite coil or any other loop antenna and make the signal receive with another audio amplifier?
I have this question in my mind because of these reasons:
1. An audio amplifier can respond to frequencies from 20 Hz to 20 kHz and when connected with a speaker, the coil in the speaker resonates as per the output frequency and if that can be connected to a loop antenna instead, it should radiate radio waves too.
2. While experimenting with a tape recorder many years ago, I encountered one strange thing. While I was adjusting the screw of the tape head, the screwdriver accidentally touched one of the head connectors that was connected with the audio amplifier. And I was able to hear an AM radio station. I guess the screwdriver was working like a whip antenna and the tape head was working like a loading coil.
So, based on these facts, I am assuming that a audio amplifier is able to transmit or receive radio frequencies without the need of any carrier wave. This would be done using direct induction just like how a matching transformer works between an audio amplifier and a speaker.
crutschow
May 7, 2021
991
No, your are not understanding the "facts".
You need to broadcast an audio signal by modulating an RF carrier frequency.
Broadcasting the signal directly as a radio wave would likely result an a signal too weak to detect, unless you had a transmitting and receiving antenna the was very large (hundreds of feed) or the transmitter and receiver are very close.
Your tape recorder experiment involved hearing the audio modulation on an AM RF signal.
It has nothing to do with transmitting an audio signal without an RF carrier.
Delta Prime
Jul 29, 2020
2,996
A professor once told me; there are three types of knowledge in this world.
1. What you know you know.
2.What you know you don’t know.
3.What you don’t know, you just don’t know.
The third type is the most dangerous.
As there is no way to prepare or defend against.
I believe you have picked a topic that you truly show interest in .
Here you go, kiddo …
ARRL Amateur Radio Education
  • RLH Unit 4.pdf
AnalogKid
Jun 10, 2015
3,058
Your professor was paraphrasing Confucius.
CHAP. XVII. The Master said, 'Yu, shall I teach you what knowledge is? When you know a thing, to hold that you know it; and when you do not know a thing, to allow that you do not know it;-- this is knowledge.
Confucius (September 28, 551 – 479 BC)
I love the ambiguity in the American version:
Know what you know, and know that you don't know what you don't know.
ak
Delta Prime
Jul 29, 2020
2,996
Indeed, he was paraphrasing Confucius. My professor of mechanical engineering had one digit remaining on both hands,it was my first introduction to Confucius;
I was 16 at a time.
To this day, I study and reference the post you have made across various electrical , electronic engineering sites. I have used your circuit solutions That you give freely to others by request.Thank you..
-Delta Prime
ofosot69
Oct 31, 2024
9
I actually know about carrier wave but I just need to confirm whether without that is it possible using magnetic field instead.
Delta Prime
Jul 29, 2020
2,996
Confirmed! You would not have asked this question; if you knew about carrier waves?
It is rare to learn from the top down.
Unless you’re like me…
:cool:You’re asking silly questions.
Danger!
Here be dragons!! :(
ofosot69
Oct 31, 2024
9
Danger!
My question was not related to radio transceiver but about audio amp. You are just trying to show yourself to be an expert without being able to answer my question properly.
danadak
Feb 19, 2021
1,104
This might help in determining effects of E field reduction, magnetic preponderance -
Regards, Dana.
ofosot69
Oct 31, 2024
9
That is because they are electro magnetic waves in stead of audio waves.
Bertus
Thank you, Bertus. You made my day! I guess, it's then possible to transmit digital signals using audio amp without the need of any modulation. Moreover, lower the wavelength, further goes the transmission.
bertus
3,877
ELF and SLF still use a kind of modulation technique.
They are used for very slow digital signals.
You can not send high speed digital signals with them.
Bertus
