Convert your projects in 3D mode
logan_dslasher
Jul 23, 2004
392
there you gow! thanks! i just wish it has a PDF or somethin'/.. i dont have web access back at home..  anyway, tahnks..
logan_dslasher
Jul 23, 2004
392
waaaa!!!!! there's a PDF file!!! Yipeee!! ehehehe..  ;D
Have fun? i will..  thanks gogo!!
Roomi
Aug 1, 2004
134
I am facing a problem with the 3d conversion.When i convert it then a horizontal bar is rendered in place of some of the components. I downloaded all the png files from the mentioned site.Are these library files? If so then where should I place these ?
omer_faruk
Oct 10, 2005
16
hi guys
i have eagla 4.13.i downloaded eagle3D and  povray.but i cant 3D.
can i help yours?
how do from eagle povray with 3D?
blueroomelectronics
Apr 30, 2007
85
I've been doing it the hard way, using Sketchup 3D.
And you can do more than just PCBs
FH16
Sep 8, 2004
26
some info's to create the 3d file
ok
create from eagle a povray file in a new folder e.g. temp.
then make mod's to file and create the ini .
copy files from ..\eagle3d\povray to \temp folder.
The exported file from eagle and the ini file must have the same name e.g. test.pov test.ini,
load both files to povray, be sure examples from povray are closed, render file, then use an animation program (e.g. gifcunstractor) to create animation.
don't use a big number of pictures, final_frame = 500 is to big, try 100 or 200 pic's
have a nice summer :)
