Current monitor/sensor
denci
Apr 30, 2012
86
Maybe because missing capacitor on ADC pin to hold voltage??
denci
Apr 30, 2012
86
ia have one question regarding heatsink temperature, so i have two IRFP460 mosfet on pretty big heatsink en testing on 4A current and i measured temperature on heatsink after one hour arround 80 degrees, so high. I made calculation and says:
P_Dmax=5A*(12V-(5A*0.1Ω)-5V)=5A*6.5V=32.5W
So max power dissipation is one transistor is 32.5W, thermal resistance THj-c is 0.45C/W. why then so high temperature, i select pretty bigger heatsink that it sould be regarding my calculations??
[SIZE=12pt][/SIZE]
[SIZE=12pt][/SIZE]
[SIZE=12pt][/SIZE][SIZE=16pt][/SIZE]
[SIZE=16pt][/SIZE]
audioguru2
Apr 6, 2004
12,026
Simple arithmetic error.
5A x 0.1 ohms= 0.5V. 12V - 0.5V= 11.5V. 5A x 11.5V= 57.5W.The heatsink thermal resistance might be 1 degree C per Watt and the thermal grease might be 0.5 degrees C per Watt. The ambient might be 30 degrees C. Then the heatsink will be very hot and the chips inside the Mosfets might be hotter than allowed.
denci
Apr 30, 2012
86
Yes, but what with 5V voltage drop on 0.5E dischatge resistor? Is this nedd to take into account, or? Now i tasted with 4A, so 2A only through each mosfet and i measured 75degree per C on heatsink so from calculation is junstion temperature is allowed range.
Is that not truth?
audioguru2
Apr 6, 2004
12,026
The datasheet for your Mosfet will tell you its maximum rated temperature and its thermal resistance.
vialop
May 30, 2016
You didn't say if the current is AC or DC, and you didn't say how much current or voltage.
Lulu123
Sep 7, 2016
Hi, you mentioned that you wanted to build a current monitor/sensor like the voltage monitor. I have some information for you and I really hope this will help you.
It is that Monitor-Current/Voltage product. You can check my link to see the detailed description of the product.
Hope you find the solution soon.
Lulu
