I changed the resitor values to 82K&10K this give me a max current of 4.36A
Not sure if it is me me, Put when I alter R20 the current does not seem stable and I get higher amps out put. I have got R20 set about half way current pot set near minimum voltge set to 15V then when I switxh on a .1R load the output current goes upto 16amps I turned if off quickly, I set R20 back to min and tired it again and I thought it was ok, But when I turned off the power supply then turned it back on and the same thing 16amps. It only does this once after that it does not seem to do it again until I turn off/on the Power.
I opened up the sim version on the PC and I noticed that is does the same in there but because it's a sim prog it's goes to 66amps but it does drop off down to it's normal current draw, I do not have the guts to let it run long enough in real life
Any ideas Why this should be happening
