Sorry it was a long day, It should have said is easy enough done. so it's a yes.Sorry, I don't understand, is that a yes or a no?
OK it was just a thought that's allThat won't work well with this circuit. Suppose you put the 1k pot. in series with the positive side of R21: altering the 1k pot will make a large difference when R21 is set to the high setting and not much difference when it's set near 0V. If you put the 1K in series with the negative side of R21, the situation will be reversed. This is why using a multi-turn pot. is the best solution.
Yes I substituted a few resitors, Maplins did not have thevalues I wanted plus rather exspensive 16P each, Rip off or what. I searched through my bins for the correct value and out of the thousands I got I gave up. but has this is just a test PCB I thought it would not matter has long they are the right values. I shall look into using a PIC to measure the time it takes to drop.I noticed that you've substituted a few of the resistors for other resistors connected in series. Did you just do it with the ones I suggested on the BoM or were there other resistors you couldn't get hold of and had to replace with two in series?
I just suggested the substitutions for the E24 values that I know are harder to get hold of than E12 values.
For the moment becasue I've got a .1R resistor for the shunt could I use a 10amp fuse in place of it means they have a lower resitance value ? I'm good at just for thoughts ;D
Saturday may be the next time I get to spend more time on it, I will try to play with it in the week if possible
