As you all probably know, the 30V power supply project on this site has many errors and design flaws.
I'm thinking about designing a new one from scratch but before I do, I'd like to know whether anyone will test it for me?
It's not something I want to build myself because I don't need it. I could breadboard parts of the design but I won't be able to completely test because I don't have all the components so I can't fully test it.
I've already nearly designed it in my head but I haven't committed anything to paper so I'll write a list of decisions I've made so far:
The design shall use a 12-0-12V transformer, when operating at voltages below 13V the power will be taken from the centre tap in a bid to save power thus cutting the heatsink size in half.
It will be a LDO regulator with a couple of N-channel MOSFETs (e.g. IRL540) used as output transistors, I thought about using P-channel devices but gain stability can be a problem and they're more difficult to get hold of.
The current sense resistor will be a very low value <50Ohm to minimise the voltage loss.
The bridge rectifier will consist of Schottky diodes to minimise the voltage losses.
Because the output device is an N-channel, the gate voltage will need to be higher than 30V. This requirement will be met by using a voltage doubler and zener regulator to power the op-amp.
I have decided to use an MC34074 op-amp because: it can be operated from a single supply, has a high voltage rating (44V), is easy to get hold of and cheap.
Perceived risks:
The current sense resistor might prove difficult to get hold of. This can be overcome by paralleling several higher value resistors.
The filter capacitor will need to be very large 22,000
Perceived risks:
