Does a diversity radio receiver really mitigate fading
ofosot69
Oct 31, 2024
9
If a diversity radio receiver works by integrating two receivers in a single radio using different antennas, then can it really prevent fading?
If the two radio receivers are in the same position and getting the signal from the same location then how will it prevent fading?
If the transmission becomes weak then both the receivers will encounter fading, isn't it?
Delta Prime
Jul 29, 2020
2,996
Welcome to Maker Pro!
It doesn’t work that way in your context!
You have been a victim of misinformation Halloween or not that’s pretty scary. Unfortunately, you must learn peace meal, the subject you raised is beyond the scope of this forum. Time to go to school….
I hope this helps you!
  • swra469.pdf
