does any one have brilliant ideas of increase in the revolution at the generator shaft?
N
Nick Hull
generator shaft?
while the revolution is rather low?
Usually rather than increasing shaft revolutions it's better to increase
the number of poles in the generator. 1024 poles at 1 rpm is equivalent
to 2 poles at512 rpm.
daestrom
In frequency, yes. But to get a useful voltage out at 1 rpm would require a
very large number of turns in the coil and/or a truly massive amount of
magnetic flux.
daestrom
V
Vaughn
Lucky Strike said:
Gear box?
Pulley ratios?
Bike chain & sprockets?
I think that the more usual approach is to use proper blade design to
increase blade speed, coupled with special generators/alternators that are
afficient at lower speeds.
Vaughn
N
Nick Hull
magnetic flux.
Frequency & voltage go together. Yes you would need strong magnets
(rare earth) and lots of turns, but that is a lot more efficient than
gearing the shaft speed up by 512 times.
