Does the Magnet with a Staurated Core get stronger if we Increase Current?
Shahriar
Mar 18, 2004
451
Hi
I want to know If I have an Electromagnet connected to a DC Voltage with a saturated Core, Can I pick up More heavy masses If I increase Current? or because the Core is saturated no difference will be?
If I can, Then what is the difference between a Non-Saturated Core with a saturated core in this example...
ThanX in advance
Shahriar
audioguru2
Apr 6, 2004
12,026
Hi Shahriar,
I think that when a magnetic core is saturated then it won't make more magnetism if its coil is fed more current. The extra current is wasted as heat.
Shahriar
Mar 18, 2004
451
Thank you Audioguru. ;)
Do you know how can I determine the Saturation Current for My electromagnet with i.e. 200 turn 26 gauge wire.
I do not have exact information about my core. it is just a piece of Iron.
ThanX
Shahriar
ante1
Jan 24, 2004
4,138
By lowering the temperature of the core and coil you can get some more magnetic power.
Shahriar
Mar 18, 2004
451
Dear Ante
Would you mind explaining a little more....
ThanX
Shahriar
ante1
Jan 24, 2004
4,138
Hi Shahriar,
I don’t know what to explain but if you keep the electromagnet cool of even better super cool then it will be more powerful.
