DSC general system tamper code
Guest
How do I get rid of "general system tamper" code on a DSC 864? I used the
DSC windows software to read the status I this code is set along with TLM
and Low Battery. The status on the keypad only shows general system tamper
as the only fault. I tried clearing out the latch error with the software
but they still show up on the status rpt on the PC. I am not using a phone
line yet and have disable TLM in the configuration. I don't have a bell
connected, so I added a 1K resistor across the bell contacts. These changes
got rid of my TLM and Bell trouble codes, but not the general system tamper?
cel
Jim Rojas
Have someone on site go into programming through a keypad and press 903.
Wait one minute, then exit programming. That should clear your problem.
Jim Rojas
Stanley Barthfarkle
What modules do you have connected?
Guest
3 keypads 5500Z and 3 8 zone expansion modules 5108 . I believe the 5108
modules are set not to report tamper I will have to double check the jumper.
cel
F
Frank Olson
Regardless of what they're set for, place a wire jumper between the
"common" and "tamper" terminals on the 5108's.
Frank Olson
http://www.yoursecuritysource.com
