Lawrence D¹Oliveiro
- Jan 1, 1970
- 0
Lennier said:I think they received coverage as being NZ's first legally married couple.
Has marriage been introduced in NZ??
Lennier said:It is a copyrighted image - (c) David R Murray Jan 2004. Permission is
granted to view that image using a web browser only while it remains on
the web server. It may not be used for any other purpose whatsoever
without my express permission.
Lennier said:They traveled to Hawaii to get married. It was very well covered on the
ZM network - in fact their marriage ceremony was broadcast live on the
ZM network.
Of course it was a big ratings grab, but it did advance the cause for
Queer marriages here in NZ.
Lennier
Yes you DO as ou are in contact with 240v..
If the Modem or PC only works on 32v then its OK, but no they use 240v..
No - I mean the first year of study which, if pursued overseas, can lead
to a doctorate from a reputable university.
What about older PCs. Do you need registration for them?
All modern computers use a thing called a
power supply, that is a sealed metal case.
No you're not. All modern PCs have the 230 V enclosed within a sealed
earthed metal case called the power supply. You only require electrical
registration if you open the case, and that case is usually riveted shut
and can't practically be opened anyway.
All modern computers use a thing called a power supply, that is a sealed
metal case. Since the voltage that comes out of it is 12V or less, you do
not require electrical registration to work on a modern PC.
PS I think you will find that
you are breaching the training providers copyright.
No Rampant Insanity instead..
Some of them are 'sealed' and plenty of them aint, sheepfucker.
ot in the Case of the Older PC , they have a external Mains switch, and Many
here have stated that they have replace the PSU Fan, I have never ever seen a
Riveted PSU.
I too have not seen a "riveted" Power Supply.
In my they've all been screwed.
So, Woger. Do you intend to back up your claim of having "credentials"?
Lennier
