Help identify this compoment...
I
Impmon
It is part of recently released Gameboy Advance game called Boktai.
This compoment is some type of sensor (called Sun sensor) that is used
to "recharge" a weapon in the game. After some trial and error, it has
been determined certain type of UV light worked the best.
Picture of the mystery compoment up close:
(bottom, the side facing light to function)
http://personalpages.tds.net/~wilykat/boktai/bottom.jpg
(top, solder side)
http://personalpages.tds.net/~wilykat/boktai/top.jpg
There are 3 leads on the compoment and 2 of them are labeled as K and A,
which suggest some type of diode. Both of the leads goes to a compoment
labeled as TLV272 (T272C on the chip). The 3rd lead doesn't appear to
connect to anything at all. Any idea exactly what compoment is that and
is there a technicial spec somewhere on the internet I could use to find
more about this sensor.
W
Wolfgang Mahringer
Impmon wrote:
Seems to be a photodiode. The component name "PD1" points in this
direction also.
HTH
Wolfgang
W
Wolfgang Mahringer
Hi
Seems to be photo diode, the component name "PD1" and the
markings A and K also point in this direction....
HTH
Wolfgang
F
Franc Zabkar
(top, solder side)
FWIW, the TLV272 datasheet can be found here:
http://www-s.ti.com/sc/ds/tlv272.pdf
It appears to be a low voltage, dual rail-to-rail op-amp with CMOS
inputs suitable for high-impedance sensor interfaces, so the
suggestion that your mystery component is a photodiode appears to be
correct.
- Franc Zabkar
W
Watson A.Name - Watt Sun
direction also.
HTH
Wolfgang
I agree. However, it has three leads, so it's possible that it's a
phototransistor. There is a chance that they labeled it PD1 but used
a phototransistor instead of a photodiode, either to confuse someone
trying to copy it, or else as an upgrade or engineering change.
But its probably a photodiode. It looks dark like silicon, so it's
probably silicon.
@@F@r@o@m@@O@r@a@n@g@e@@C@o@u@n@t@y@,@@C@a@l@,@@w@h@e@r@e@@
###Got a Question about ELECTRONICS? Check HERE First:###
http://users.pandora.be/educypedia/electronics/databank.htm
My email address is whitelisted. *All* email sent to it
goes directly to the trash unless you add NOSPAM in the
Subject: line with other stuff. alondra101 <at> hotmail.com
Don't be ripped off by the big book dealers. Go to the URL
that will give you a choice and save you money(up to half).
http://www.everybookstore.com You'll be glad you did!
Just when you thought you had all this figured out, the gov't
changed it: http://physics.nist.gov/cuu/Units/binary.html
@@t@h@e@@a@f@f@l@u@e@n@t@@m@e@e@t@@t@h@e@@E@f@f@l@u@e@n@t@@
