Help identify this fuse
danm
Feb 20, 2023
4
My LED driver isn’t working because this fuse is burned out. How do I identify it and find a matching one?
Thanks!
Martaine2005
May 12, 2015
5,317
That’s not a fuse, it’s a diode.
How do you know it’s burnt out?. How did you test it?
Martin
danm
Feb 20, 2023
4
Oh! That is super helpful. I tested it with continuity mode in my multimeter. It looks ok in diode testing mode. I will continue to troubleshoot.
Thanks for the quick response!
Martaine2005
May 12, 2015
5,317
Approx 0.5 - 0.7 in one direction only and 0L the other?. All is good with it.
What’s the main issue?
Martin
bertus
3,875
As there is ZD next to the diode, it is a zener diode.
Bertus
danm
Feb 20, 2023
4
Thanks folks! The overall problem is that LED lights in my rangehood aren't working. I misdiagnosed it. The driver seems to be producing steady voltage. One of the LEDs is bad and since they are in series, both LEDs are off. I just need to buy a new LED.
Unfortunately, the manufacturer hasn't specified the specs for their LEDs and LED driver, so I will have to keep buying from them with very high markup. See https://kobe-range-hoods.myshopify.com/products/led-driver-c1-0402-d001 and https://kobe-range-hoods.myshopify.com/products/led-lights
danm
Feb 20, 2023
4
Thanks Martaine2005! I am located in San Francisco Bay Area. I will buy their LED this time and then do a surgery on the old LED to prepare for the next time.
