Help needed w/ 9v Cannon ignitor
Boomer
Sep 15, 2009
3
Hey folks, I'm new to the forum and in need of a little help. I've built a multi-barrelled black powder cannon and I'm trying to build an ignitor panel. I have 6 spst toggle switches with leads running to each barrel with a Christmas light filament as ignitor. I am using a 9v battery as a power source and trying to hook up the toggle switches in series.
I'm missing something basic here. I've tried running the individual leads back to the battery - yet the 6 switches all want to act as one - ie they all must be on and vice versa. I also tried hooking them up with a bypass/jumper thinking that the current would bypass the closed switch and travel to the open one - no dice.
I apologize for my ignorance - any help would be appreciated. I am trying to keep this as simple as possible! Thanks in advance.
RaleTheBlade
Sep 12, 2009
4
Couldn't you connect them all in parallel? One common source and one common ground? That way any of the switches can work without needing any of the other ones on. I wish we had a draw tool but this will have to do I guess, lol.
------------------------ > Ground
L1 L2 L3 L4 L5 L6
S1 S2 S3 S4 S5 S6
------------------------ < Vin
Ugh... that looks like crud. It'd be really cool if this forum had something of a "drawing" board where you could sketch circuit schematics. But... I hope you get my jist :)
Boomer
Sep 15, 2009
3
Using a 9v battery can I use a ground? All the diagrams I've found idicates that the path needs to be circular. Thanks for the quick response.
RaleTheBlade
Sep 12, 2009
4
Well the current has to go somewhere, and if its coming from a higher potential source (the + on the battery) then its going to want to go to a lower potential source (the - ground) to equalize the current. Im pretty new at this whole electronics thing myself so Im trying to use logic to deduce an answer, haha.
Resqueline
Jul 31, 2009
2,848
Current can't travel to an open switch, only voltage can go to an open switch (but won't pass through of course). Current (& voltage) can only travel through a closed switch.
You're right in that the circuit needs to be circular as you call it, but that only applies to each individual switch-lamp circuit. Do one ignitor first and then add the others in parallell to the first (do not break into the first circuit) in turn, like Rale suggests. Did you understand the diagram? It's correct.
The term ground has no real meaning in a floating, battery powered circuit like this - only positive and negative battery rail applies.
