Help to identify relay pins
14,317
First indication of a working relay: Does it click when power is applied to the coil?
dave9
Mar 5, 2017
1,191
Looking at the datasheet, you should measure approximately 150ohms on the two coil pins with a multimeter.
Without powering the coil, you should measure almost zero ohms between the common pin and the normally closed. Powering the coil you should measure infinite resistance between these two and almost zero between the common pin and normally open, and of course you should measure 5V on the normally open to the LED if 5V is connected to the common pin.
Have you tried it without the relay, providing 5V to the resistor and LED in series? Maybe the LED is bad.
Djsarkar
Jul 27, 2020
46
Hi
Yes I get click when 12v dc power is applied to the coil of relay. There is no fault with led. I have tested and it woks fine
Well then, show your wiring......
You do realise you will have only 3 mA flowing with a standard LED and the 1k resistor...??
14,317
Your connection looks right. Try the other contact (NC). The relay should work inverse: relay on = LED off and vice versa.
One issue with this relay could be the relay contacts. This is a power relay meant to drive high current. The contact material is a silver alloy. Silver alloys will corrode over time, building a non-conductive layer of oxide over the contact. With high power loads this is not an issue as the oxide will be removed with every switching cycle due to the high current. A low load such as your LED may not be able to overcome the oxide. Try a high-power load instead of the LED to see whether this "cleans" the contacts.
Here's some background reading on this effect.
Djsarkar
Jul 27, 2020
46
Thanks there was bad cable connection so I have replaced cable and now relay is working fine with led
