help with IR2110 chips
Maglatron
Jul 12, 2023
2,025
is there any way that you can send me a high res picture of image 8 because i cant quite make out the numbers next to the components and my internet wont let me through to the site, when I clic the image it says,
Did Not Connect: Potential Security Issue
Firefox detected a potential security threat and did not continue to 4.bp.blogspot.com because this web site requires a secure connection.
i dont get how to make the gate voltages high enough to turn on the fets because if I'm putting 80volts through the highside fet then when closed the source will be 80 and with a gate to source threshold is 20v then I need a voltage of 100 at the gate, now if the boostrap provides the gate with a high enough voltage and drops 5% of its charge and then switches back to charging when the low side fet is on, theres something there that I am missing and so i thing the bootstrap cap has a use in keeping the vgs theshold of the high side fet kindof make sence but then where on earth do you get the 100volts to open the lowside fet gate, confused and struggling, I might need it re-wording because I can't make sense of it as of yet, thank you for your help.
I now understand that when you're driving a low-side MOSFET (source connected to ground), the gate voltage only needs to be elevated with respect to the source pin. So if you apply a Vgs of 10V, the gate is at 10V, and the source is at ground. This is sufficient to turn on the MOSFET fully. high side For a high-side MOSFET (source NOT connected to ground), the situation is different. If you have a load voltage of 55V and you wish to turn the high-side MOSFET on fully, you would indeed need to elevate the gate 10V above the source (so if the source is at 55V due to load, the gate needs to be driven to around 65V relative to ground). That's why high-side drivers like the IR2110 use a bootstrap circuit to generate this elevated gate voltage. I am also using 55volt now instead of 77 because in a square wave as opposed to sinosoidal the rms equals peak voltage now what i want to do is make use of IRF640 mosfets because they switch fast enough for 50hz now im trying to choose a capacitor diode and mybe i need a bootstrap resistor too, any additional thoughts welcomed!
i think 10uf at 100v should do it what do you think about this because I consulted another source but in your pdf document it reccomends 47uf - 68uf what are your thoughts
please, I need a high res image of the picture in image 8 of the pdf because the actual picture is a link in the pdf and my internet connection won't allow me to view the page
so i found this on another thread
"Sorry guys i forgot to tell you that i didnt connect the source of the low side mosfet in to ground ... but i connect it to the negative voltage (-310V)
So the output is alternating current isnt it ?
*see the red circle"
does this mean that i can create the alternating current with just one half bridge ir2110, I want to understand this
Minder
Apr 24, 2015
3,561
Sorry I just got to it, but the low side has to be referenced to GND or supply common.
As shown in fig 8
Maglatron
Jul 12, 2023
2,025
Can I please have a high resolution picture of fig 8 because I cannot access the picture through the pdf on the internet that I have
As shown in fig 8
Maglatron
Jul 12, 2023
2,025
thanks but no, it's still blurry when zooming in
can you get me a clearer image please?
also could I have the image early in the day because I want to get on with building the circuit in the design simulator? thanks, awaiting your responce.
Maglatron
Jul 12, 2023
2,025
uk time great british greenwhich marridian its 2 o'clock in the afternoon right now early for me is before 12 noonday
can you get the image in high resolution?
Alec_t
Jul 7, 2015
3,821
No chance. The original Fig 8 image on the author's web-site is blurred.
Maglatron
Jul 12, 2023
2,025
can you make out the values for the
8 resistors
6 diodes
8 capacitors in the picture
I can make out the pins for the IR2110 and I have chosen the MOSFETS as IRF640 N-channel
perhaps (if you can make it out) you can modify the blurry parts out in paint and write over them with with a text box telling the component number and value.
If you can do this I would be forever greatfull
Minder
Apr 24, 2015
3,561
Try this.
  • Tahmidblog.pdf
Maglatron
Jul 12, 2023
2,025
Try this.
thats where I got the original image, I cant zoom because it blurs, and can't click through the image because of the internet connection I have sees the website as a threat, I need to know the values of the parts
where are you from just out of interest?
Maglatron
Jul 12, 2023
2,025
cool, nice weather? whats the time there? do you think that you can re-label the blury picture if you want to, if you don't mind?
Minder
Apr 24, 2015
3,561
C1- 22uf, C2- 100nf, C3- 22uf, C4-100nf.
D1,D2,D3 - UF4007
R1,R2 - 10R,
R3,R4 -1K.
The other side same values for these components.
Minder
Apr 24, 2015
3,561
Incidentally you have the values already in post #36 !
Maglatron
Jul 12, 2023
2,025
sorry about that i will go back and look, one thing is that I'm looking at the circuit and there are 4 more caps c3 and c4 and c6 and c7 in the picture
