Martaine2005
- May 12, 2015
- 5,318
- Joined
- May 12, 2015
- Messages
- 5,318
Hot glue is definitely not the way.
magnets stuck with super glue coils stuck with hot glueHot glue is definitely not the way.
Not strange. Inductors don't obey Ohm's Law.what is strange is that it seems like ohms law isn't working
Does that mean with the coil short-circuited?also I measured the amps strait off of the coils
yes going to try a few different ideas now, I'll get back to you over the next week! thanks also taking off the pennys I think they are disrupting the manetic flux to be fairDoes that mean with the coil short-circuited?
You are not listening..,yes going to try a few different ideas now, I'll get back to you over the next week! thanks also taking off the pennys I think they are disrupting the manetic flux to be fair
I have seen this before and I am witnessing it now you are picking and choosing informationPutting pennies in the gap will introduce eddy-current losses
That conforms to your thought process.
I find this intriguing because you find it difficult to test alternative hypothesis in parallel.
You are focusing on one possibility and ignoring alternatives.
I have mentored individuals who make systematic errors in scientific research based on inductive reasoning ,which is the gradual accumulation of supporting evidence.
Excluding myself well educated and well informed individuals are trying to help you and you are ignoring them... Time becomes more precious when there's less of it . You are wasting their time.
there is also the fact that the coils were remounted from the time before so I expected a different result anyway. I'm going to build from the bottom up with some modifications to consider to make it better and more stable I'll get back to you when I make some progress and reach the same point that I was at with space for more coils and tighter tolerances new drive train and hopefully get to a point where I can get to use the inverter that I built with the IR2110's which this thread started from and again thanks for your help and I hope you don't see this as waisting your time! I'm learning a lot, thanksNot strange. Inductors don't obey Ohm's Law.
Your new readings indicate that the coil inductance when using the 20 Ohm load is less than it was when using the 100 Ohm load. This is likely because the higher test current is causing partial magnetic saturation of the steel core.
Saturation of the core would result in the waveform being distorted, no longer sinusoidal, hence your current readings being unreliable.
In that case perhaps you could experiment with an air-cored coil for comparison?I'm going to build from the bottom up
All magnetic fields are created by electrical charge meaning even a static magnetic field a in a permanent magnet . The charges are moving because the electrons are orbiting the nuclei .go on then why don't you have a suggestion or idea apart from "you are wasting your time" at least Mr Alec_t is trying to help you're not helpful and you always put me down, when you can.
A modern United States minted penny is made of copper plated zinc. Both copper and zinc alloys are non-ferrous materials...Adding a penny or any other ferrous material to lessen the air gap between a magnet and the core of a coil can indeed have an effect on the magnetic flux and the performance of the coil. This is because ferrous materials can act as magnetic conductors, effectively channeling and concentrating the magnetic field lines
Very true, since 1992.english pennys are well and truly very magnetic
By reducing the air gap, you're providing a more direct path for the magnetic flux to flow from the magnet to the core of the coil. This can increase the magnetic flux density in the core, which in turn can increase the induced voltage in the coil according to Faraday's law of electromagnetic induction.
