How to make my fan spin faster?
Kucabara
Mar 15, 2014
I have an USB powered external laptop fan. How can I make them spin faster? I'm only using one of the fans. Will I get faster speed if I remove one of the fans? Thanks for your help. I don't have much knowledge in this, so go easy on me. :)
UbLVE7NXefC9VGC3KIxj_2FX9EcBJC_omDEpKj6aKXs
btdU9iwAUiW9-3S6b1L0kl_sO9QCbC0kAC2RQIqF5FU
aRE1ze6KlmLstmPyKt9N_kOEVBoM_AIg9OFbr7AQfTs
14,306
Welcom aboard this forum.
These fans seem to be connected in parallel. Removing one will not change the speed of the other. You will save some power only.
Making the fan spin faster will probably require a higher voltage than your USB port provides.
cjdelphi
Oct 26, 2011
1,166
Higher voltage, basically... you could use PWM to vary the speed to suit your needs.
14,306
With PWm you can only reduce the speed, but never increase it above the max. speed without PWM.
B the way: if these fans use brushless motors, simply increasing the voltage may not work. On the contrary, it may damage the electronics.
