identify temperature IC
jfk
Mar 28, 2016
13
I've seen an temperature IC that drops the voltage out of a pin as the chip warms up.
Is anyone familiar with what it might be?
jfk
Mar 28, 2016
13
Doesn't the LM35 raise output voltage as temp rises?
Arouse1973
Adam
Dec 18, 2013
5,178
You could use an inverting buffer to invert the signal. Don't know of an IC that goes the other way, Maxim might do one.
Adam
AnalogKid
Jun 10, 2015
3,045
There are thermometer (temperature transducer or sensor) IC's and there are thermostat ICs. All of the sensor's I've seen have a positive output coefficient - voltage goes up when temperature goes up. Thermostat ICs do not make a linear output. The output is a digital logic low or high, and it changes state when the temperature crosses a threshold. The direction of the change varies with the chip, or some chips produce both.
Dozens on the market. Part number?????????????????????????????????????
ak
jfk
Mar 28, 2016
13
Agreed on all that. Thanks. The circuit I saw was unusual, so just trying to figure out what they did.
