Is it a hartely oscillator??
walid1
Jun 27, 2004
749
Is this circuit using a hartely osc.?
if yes please answer these questions:
1- is the emitter resistor affect the frequency of oscillation?
2- this is a transmitter circuit, is it FM or AM and why?
thank you very much.
audioguru2
Apr 6, 2004
12,026
Hi Walid.
Yes, because its coil is tapped and provides positive feedback to the base of the transistor.
No, it affects the current in the transistor which changes the output power.
It is simply a continuous carrier frequency without AM nor FM modulation.
If something modulates the amplitude of the carrier then it is AM. If something modulates the frequency of the carrier then it is FM. Some simple modulators produce both at the same time.
walid1
Jun 27, 2004
749
Thank you guru it is good and fast answer
Now you this is only an oscillator niether AM nor FM
what you think it used for?
thank you guru
walid1
Jun 27, 2004
749
Like this:
http://www.talkingelectronics.com/projects/27MHz%20Transmitters/27MHzLinks-1.html
i understand you the reciever sense the carriar if ther is a cariar it do somthing like moving forward if no carriar do somthing else.
thank you guru
Kevin Weddle
Feb 23, 2004
1,620
The hartely oscillator has many drawbacks as do ther other simple oscillators. It could have to do with the resonant frequency of the LC and the ability to get high enough gain. It may also have to do with any change in load conditions that could prevent or stop oscillation.
walid1
Jun 27, 2004
749
Please i didn't understand.
what if we use a buffer circuit between?
thank you KevinIV
Kevin Weddle
Feb 23, 2004
1,620
A buffer circuit is needed. Most oscillators I've seen have a whole lot of transistors. There only a few capacitors and or inductors used to resonate.
Kevin Weddle
Feb 23, 2004
1,620
Is there any reason for the center-tapped inductor being standard to the Hartley Oscillator? Using two inductors should allow for a better design because this part of the circuit has less tolerance. Or is there a mathematical advantage to using the center-tapped inductor?
audioguru2
Apr 6, 2004
12,026
A center-tapped single inductor is used because it inverts the signal. The collector of the oscillator transistor produces a signal at one end and the base receives the signal at the other end. The signal is inverted to produce positive feedback to sustain oscillation. The transistor can have a voltage gain of only slightly more than 1 and the oscillator still works.
Kevin Weddle
Feb 23, 2004
1,620
The circuit layout can produce 270 degrees of feedback. Is C1 and the emitter resistor used for any of the phase lag, or is C1 just a coupling capacitor?
Hero999
Oct 28, 2007
2,433
Not if the circuit is assembled correctly.
C1 AC couples the feedback from the inductor to the transistor.
I'd be surprised if this circuit works at all with R1 at 1M. The proper way is to bias the transistor with a potential divider.
Kevin Weddle
Feb 23, 2004
1,620
Then C1 has a low impedance compared to the transistor input impedance? Where is the collector voltage compared to C1 input voltage?
audioguru2
Apr 6, 2004
12,026
A simple calculation shows that the 1000pf of C1 has a reactance of only 5.9 ohms at 27MHz so it is almost a dead short with no phase shift.
The center-tapped coil has 45 turns on the collector side and the same 45 turns on the base side so the base signal is the same amplitude as the collector signal.
The center-tap makes the coil like a teeter-totter. When one side goes high then the other side goes low which is 180 degrees phase shift. The transistor inverts so it also has 180 degrees phase shift. The total phase shift of 360 degrees results in oscillation.
Kevin Weddle
Feb 23, 2004
1,620
The variable capacitor has to be a higher impedance than the series inductor so that the collector voltage is inverted compared to the base voltage. Unless the feedback capacitor and transistor base add to the phase shift, the amplitude is reduced by at least 75%.
audioguru2
Apr 6, 2004
12,026
No.
I explained how the center-tapped inductor inverts the signal with 180 degrees phase shift so the transistor provides the other 180 degrees phase shift for it to oscillate.
Hero999
Oct 28, 2007
2,433
No.
Yes and no doubt he'll ask the same question again and again.
