microcontroller ROM copy trouble ?
robb
I have a working (ie. tested) microcontroller board uses a
(Philips MAB-8031-AH-12p) MCU a 8051 variant, maybe romless ?
with a (NEC 23256AC) ROM chip.
i removed the ROM chip (NEC D23256AC) and copied it using a ROM
programmer, then i programmed that ROM image onto a (ST M27C256B)
EPROM
i put the new ROM (ST) onto the microcontroller board and i
t does **NOT** work ... a no go.
i removed the ROM (ST) and put the ROM (NEC) back and works like
a charm... no problems
i download ROM images from both (NEC) and (ST) and compare in
file compare program which declares them as exactly the same
HELP please?? any ideas what is going on here.
the only funny thing about the microboard (that i know) is that
the ROM memory socket has (pin1) tied to (pin 27) that is Addr15
(pin 1) and Addr 14 (pin 27) ??? do not know why ????
thanks for any help i am stuck again,
robb
Rich Webb
EPROM
One possibility is that the speed grade of the EPROM is slower than
that of the original ROM chip. There should be a couple of digits
after a dash on each chip, like -12 or -70. What are they?
robb
Thanks for reply Rich,
I have a variety of ROMs i have tested
i have a set of uv eraseable and OTP
both of the 10 12 15 variety (ie. 100/120/150 ns)
the original equipment is from 1987-89 ...so i do not think it is
terribly fast,
the clock is 12 Mhz. I could not locate an exact datasheet for
the (NEC D23256AC 016 8437k9) but the one 23256ac i did find
was rated at 150 ns
i tried to match or better that number.
faster than spec chip is OK i presume ?
the 8031 processor has a Time of Address Valid to Instruction
Read Valid of 300 ns (max value)
do any of these numbers sound close (bad) ?
****And more info****
... There is no funny business with 8031 processor because i was
able to sub in a **brand new/ not used ** Atmel 8031 processor in
place of the original 8031 and worked great ???? with the
original ROM if that means anything
Thanks again for your help i am really stuck here and wondering
if there is some security measure installed on the original ROM
but that just seems unlikely ???? unless that funny stuff with
the Address line has something to do with it ???
but my reconing on that is.... if i have the same raw image on
the two ROM chips then the processor sould see no difference in
the data it reads from either chip using the same interface to
those two chips ? yes /no /maybe ?
Thanks again for help Rich,
robb
robb
[condense]
Copied the old ROM to a new chip, verified new chip
** but** new ROM chip does not work
Thinking there might be some MCU 8031 funny business/security i
swapped a ** brand new / not used** (Atmel 80C31x2-UM) in place
of original 8031 and works like a charm...
........with the **Original ROM ONLY ***
could really use some ideas , i am stumped,
robb
TT_Man
terribly fast,
was rated at 150 ns
My guess is that here is a subtle pin difference between the eproms... speed
is definitely NOT an issue.
Rich Webb
was rated at 150 ns
It *looks* like the memory chips are faster than the processor, so
that may not be the issue. The original was probably 160 ns.
The note at the back of the TMM23256P data sheet (I'm guessing that
is the one that you also found) does reference a required initialization
sequence. If you can, scope out which of the two sequences are used
and perhaps determine whether that sequence is disturbing the alternate
chip in some way.
John Fields
EPROM
Eeyore
John said:
If the same image is programmed into both devices
You didn't read what he wrote did you ?
He has an *external* ROM.
Graham
I have a working (ie. tested)microcontrollerboard uses a
EPROM
i put the new ROM (ST) onto themicrocontrollerboard and i
robb
Been there (or somewhere similar). Is Vpp connected? (to Vcc?).
In the case I saw EPROM's programmed & verified (in programmer),
but the output disappeared almost instantly in the real circuit
where Vpp wasn't connected (to Vcc). (2716's).
Ryan Weihl
if memory serves me right the 27... is a progamable chip and you
apply a programming voltage to a certain pin. To read that chip
you must change "that" pin to hi or low.
I got on datasheets here.
robb
chip in some way.
Thanks Rich,
I scoped the working chip in operation and i saw wave forms i was
not expecting ? the (pin 1) was particulalry different
/peculiar.
i will ooku pthe sequence next and see if i can decipher what i
see.
thanks again ,
robb
Eeyore
/peculiar.
What is pin 1 of the ROM connected to ? It may simply be floating.
Try tying it low.
Graham
robb
well oddly on this board the (pin 1) is hardwired to (pin 27)
for the original chip that is ( NC to Addr 14) on the **new**
27c256 that would be (Vpp to Addr 14)
so i **tried** insert new 27C256 into socket with (pin 1) not
making contact(bend pin and slide to outside of socket) then
attach micro-jumper hooks from (pin 1) to Vcc
and this did not have any effect ??
so now i am wondeing if i am even reading the original Chip
correctly it is ***NOT*** directly supported /mentioned in my ROM
reader but it has similar equivalents by my judgement but the
data does not look like it is thr 8051 processor instructions as
i would expect.
thanks for help ,
robb
Eeyore
i would expect.
You could try running the ROM contents through a disassembler. That should
tell you if it's junk or not.
Graham
Rich Webb
robb wrote:
[snip...snip...]
i would expect.
*Reading* is (nearly) universal for memory chips with a standard
pinout. *Programming* is often vendor-specific and not well
documented in end-user data sheets.
Have you tried running the object code through a disassembler?
I've used D52, which is available at http://www.8052.com.
That doesn't sound odd as pin 1 would be A15 on the next
size up ROM.
OK, so that's not the problem.
i would expect.
Have you looked at a hex dump of the ROM? Perhaps
it didn't really enabel the ROM when reading it and you
"read" all FF or something like it from the original ROM and
it programmed your new EPROM with that.
Mask ROMs can have additional chip selects (if pins are
available) and these can be (mask programmed) to select
on high or low. There may or may not be an OE (possibly
just the chip select(s)).
It's a 28 pin chip and has to have gnd, Vcc, 8 data,
15 address so that leaves 3 pins. The eprom
has CE, OE, and Vpp; the ROM might have
3 more chip selects or some number of chip selects
plus OE?
It sounds solvable...
robb
chip in some way.
uhmm....
any ideas on how to scope an initializing sequence ?
it's to fast or my adjusting or triggering is a problem ???
robb
mpm
thanks for any help i �am stuck again,
robb
Honestly, I just skimmed the replies, and don't have the time to get
into great detail about what might be wrong....
However, if I recall correctly, parallel EPROMs used to have
"Signature Bytes".
In the old days, that's how a programmer "knew" what programming
voltage / algorithm to use....
Could be the 8031 code is reading this, before allowing normal
operation. (Wild ass guess, btw)
Or, perhaps more likely, your programmer isn't really programming the
new EPROM and its just lying to you.??
Hope you figure it out. Good luck.
-mpm
budgie
i would expect.
Vpp needs to be held at Vcc for reading. If it floats you will get garbage
results.
