Eeyore said:
Do you have a plain 'vanilla' example of an 8051 application circuit
with external ROM showing the connection of the address and data lines
(and address latch) ?
In view of comments made, I suggest that you 'buzz out' all the address
and data line connections between the 8051 and the ROM on your board and
report back to establish if there's anything unusual here.
Appologies for late turn around reply,
finishing up X-mas mode, returned from 4 hour drive to relatives
this PM.
Just wanted to give a quick reply before sleep.... so that you
didn't think i gave up on your much appreciated help.
The ROM/MCU does connect to other chips but does not go through
them. That is, my original pinout diagram of the ROM lines to MC
line relations holds true, there are direct traces from the ROM
Addr/Data lines to MCU's ports 0 and 2.
but also the ROM Addr 0-7 is connected to the inputs 1D,2D
etc.... of 3 diff SN74LS377 (D-Type Flip-Flops) the output of
the Flip-FLops 1Q,2Q ... connect to either a Static Ram chip's
(SRM2016) Address lines and the SRM data lines are also connected
to the I/O port 1 of MCU
the LS377 has connections to other chips around the MCU eg.
(74LS251, 74LS28B, 4049, others)
I will work on a more complete pin connections, i origianlly just
posted to show that the ROM pins were consistent with 27cXXX
series chips.
My chepao chim=nese reader did supoprt the chip that someone
suggested the D87c257 and i get something alot more promissing
shown below...
i do not know if it is good yet as i do not have any more blank
ROM chips to burn and i have not tried to load into a 8051
dis-asembler
thanks for all the help Graham,
robb
D87c257 read....
:020000040000FA
:1000000002096FC0D0C0E0020173FFC0D0C0E0029F
:1000100001BEFF30B202D22A32FFFFC0D0C0E0C022
:1000200082C083C000904058E531540F204C073007
:1000300045036001040423F893F58DE80493F58BE0
:10004000E542540790405093F8E541540793C44863
:10005000758360F0206F26D294E530758350F0E50B
:100060002D543F7041C245C28E206F19205D1E1273
:100070000F39D000D083D082D0E0D0D032204DD9FB
:100080007530FF80D4205C4C12154A80E5E5422093
:10009000E002C294E530758350F080D6E54120E05F
:1000A000F353307780EE14601314147002D24CE5D1
:1000B0003130450C540F600215313164316480B227
:1000C000C4B53109C24C1046F1D24580ED104CEA5E
:1000D000053180E6104DC5E520440F20E701C4F549
:1000E00030758DFBD28ED24D53200F80854320F08A
:1000F000E52D543F603AFDF5317842306F0118E646
:1001000030E0021531E531C313B4020575310A80C0
:100110000DC394035001E4C3139246C4F531E6D2F3
:100120004C20E009C24CED1460031201641201641A
:10013000208E20306F06E530C4B53009758DFF750F
:10096000D23D22D23C22E0540F24F650F3808D7504
:1009700090CC797E7802760008D9FB75B8E175894C
:1009800011758CFE75880575A8867583607444F0B2
:1009900075835074FFF530F0758D88D28ED2137543
:1009A000530AD28C120D60308FFA7583507477F52C
:1009B00030F07455758360F0C28F758D88120D60AC
:1009C000308FFA906007E030E002D20A756DE0D215
:1009D00014D2131230A8754400C22C121808C28E0B
:1009E000C28FD2AB1229FCD2192019F82018F5A217
:1009F000B492E0A2B592E1F45403F52B3014102028
:100A0000200D204A472010031218EAC214C2131204
:100A100029FC304A082011E4200DE1800DE5445402
:100A2000F0B4F006202FD52010D220182AD293D26D
:100A300092C295C2D3C2D4A2B492E0A2B592E1F41C
:100A40005403FAE52B5403B5023980B02011BC20C1
:100A50000DB91231A780B4D2193014057553008036
:100A60009B3018C93092298043501E120CAEEA60A8
:100A700030B4030A205A12D25A1213157403120DFD
:100A8000428006EA20E0E250E2532BFC422B21FC9C
:100A9000C293D295C291E543B4569CC290D2A8802D
:100AA00096305AE5C25A120EA5E480DD7552A0C2F6
:100AB00093D292C20A304102D291E543B45602D297
:100AC00090752E00750600D215754D00120CAEC241
:100AD00089D2A8301E04C22AC21EC25A205646E538
