Need A Circuit To trigger An Event Above 2 Volts
bigshop
Jun 24, 2013
I need a way to monitor a DC circuit so that once it reaches 2 volts I can turn on another circuit, then once it falls below 2 volts turn off that circuit
Anybody have an example
14,317
Google Schmitt-trigger - you will find lots of circuits.
Actually what you describe would be accomplished with a comparator.
However, a Schmitt trigger is a better option because it will not switch rapidly back and forth when the signal is at or very close to 2V.
For your case a comparator with a small amount of hysteresis (there's some words to Google with) would form a schmitt trigger that may solve your problem.
