opamp outputs a high signal even when the input is 0
sherazi
Mar 8, 2010
91
i am using this circuit , and the problem i am facing is that sometimes when the input is becomes enough to make the output high and then gets to 0 value the opamp still outputs a high value, is there any way to ensure that ouput comes to 0 after the input has gone low...
the circuit is for a vibration sensor, and the input is induced in the coil via a vibrating magnet on the spring ...
sherazi
Mar 8, 2010
91
its the output of first opamp that remains sometimes, and when the spring again vibrates then goes normal again ...
A schematic may be useful.
