Power Supply
bigkim100
Apr 17, 2013
270
Ok, so I need a brute force 12v 6 amp (at least power supply. I bought one for 10 Canadian Bucks at a Rummage Sale, and it outputs only 9vdc. It uses an oooold± Silicon transistor 2n6576 and a ooooold 723c control ic.
Is it worth getting this thing going with a new circuit, as it has a monstrous Transformer and bridge rectifier, that all seem to be putting out correct voltages. It includes a nice big heat sync and a really heavy duty case.....should I keep it , or trash it??
The schematic (sort of) is included
bertus
3,849
Late Tony van Roon made a benchtop power supply using the LM723.
In the schematic yoy will see wich components vary the voltage.
Bertus
  • Bench top power supply Tony van Roon.pdf
crutschow
May 7, 2021
987
Since the transformer apparently has 20Vac at the secondary, there should be more than enough rectified voltage to allow the 723 to provide 12Vdc at its output.
14,289
This supply uses mostly robust components. A failure is unlikely with one exception:
The most common issue here would be a fail of the electrolytic capacitor C1. As this power supply is obviously old, this capacitor may (will) have lost most if not all of its capacity. Replace by a new 4700 µF (or higher) 40 V (or higher) type.
My glass ball shows me a > 90 % chance that the power supply will work after that replacement.
If not, the regulator may be limiting the voltage due to external issued.
  • Check the contacts of the current limit select switch (1.5 A, 150 mA, 15 mA) for good contact, clean them with contact cleaner if necessary.
  • Check resistors R5, R6 and R7 for correct value.
  • Check potentiometer VR1 for good contact, clean if necessary.
  • If you have an oscilloscope, check the output voltage for cleanness. Is it clean or is there a noticeable ripple on top?
Regards,
bigkim100
Apr 17, 2013
270
I was lucky enough to find a basic schematic using the ic and transistor. With the schematic, I was able to remove all the assorted jigged up wires, that I think someone had used to bypass the ic. Many wires later, and a pile of wires removed I found that it worked perfectly. I have added a fuse, front panel Power On light, and used solid wire (since its supposed to put out 6 amps). I also replaced the 2 conductor wire with 3 conductor, so the metal case is grounded. So I now have a nice solid 12 v supply. I think what confused the original owner was that both the input and output negatives of the unit were common, and once I corrected the fact that he had disconnected this, it sprang to life. Thank you everyone for all your help, I do appreciate it. PS I also mounted the PC board that was just flopping around the inside of the case...Jeeeze...what were they thinkin!
Martaine2005
May 12, 2015
5,285
Do you mean primary and secondary?
Somebody will correct me, but wont that circumvent any isolation from the transformer?
Martin
bigkim100
Apr 17, 2013
270
Im sorry, I meant the low voltage dc side, pre and post regulation. Thank you tho
