Sallen Key Low Pass Filter, bandpass filter
Maglatron
Jul 12, 2023
2,025
I built the preamp today for the 12k i used a 10k and 2k in series and for the 27k I used a 22k and a 4.7k will that be sufficient I can swap it out if not when my other resistors come in the post!!?? I'm not wure which rating ie 12 24 I got because I got my mum to order them, they were off ebay, and I can't use ebay where I am!
Maglatron
Jul 12, 2023
2,025
so will this leave the cap values the same? I've bought them now! I will write out the new list of resistors tomorrow because I'm knackerd right now, busy day:)
Here is an example with E24 resistors for the 7000 Hz filter:
This will reduce the number of values for the resistors.
Bertus
Maglatron
Jul 12, 2023
2,025
So I've written out all the resistor values, thanks for the tip about using the E24 series, very helpful! and the caps values stayed the same so I can still use the ones that I bought!
Maglatron
Jul 12, 2023
2,025
That will be absolutely fine. If it’s necessary.
Thank you for confirming think I have project time tonight making 12 filter boards 4 REF GND boards and 4 envelope detector boards and adding thee amp to the same board as the preamp won't get it all done tonight but I plan on making a small dent in the work, might not have chance yet but we'll see!! also making power supply board that has USB's sockets and 5 volt regulators and switches for the 12v on and 5volt on have a bit to do also the LM3914's have come so for 2 chips on each band I'm going to be using 32 of them!
bertus
3,877
Strange that you do not have a 27K resistor.
It should even be in the E12 series.
Here is an overview wich values are in E12, E24, E48 and E96 series:
Bertus
Maglatron
Jul 12, 2023
2,025
not sure if I made a mistake for the bufferREF circuit I didn't have the 500k resistor so the choices were 470k or 560k I went with 560k, can always swap out when the new resistor come and to bertus I think I've just misplaced them to be honest! will 560k be alright?
bertus
3,877
Where are the 500k resistors?
The REF circiut uses 2 10k resistors in the voltage divider.
There is a 500k resistor in the amplifier.
With the 500k resistor the gain is 5 times.
With a 560k resistor the gain is 5.6 times.
With a 470k resistor the gain is 4.7 times.
Bertus
Maglatron
Jul 12, 2023
2,025
oh shit sorry I thought it said 4.99k got mixed up and I mixed it up with 500k it's R4
bertus
3,877
A 4.7 k will be fine for R4.
The value should be about the parallel value of the voltage divider resistors.
Bertus
Maglatron
Jul 12, 2023
2,025
4.7 good to go, going on it later for 30 mins and was going to build the amp would the 560 k suffice for that or could I use the 470k or shall I just wait untill the new resistor pack comes and use the 510k?
bertus
3,877
Just see how the amplifier behaves. As said that resistor sets the gain.
Bertus
