The Electric Car
Jim Thompson
Methinks you're another brown-noed minion of the Third Reich, or
perhaps of something far worse since you folks continually claim to
know all there is to know, and then some.
- Brad Guth -
And you, sir, are a village idiot, most likely a leftist weenie as
well.
Only leftist weenies are ignorant enough to think that engineering is
accomplished via expression of emotion, while ignoring engineering
derivations or the laws of physics.
...Jim Thompson
BradGuth
Expensive, who cares? We're talking about the
ENVIRONMENT, we can't worry about filty lucre.
What are you, a greedy Republican?
Let the gov't fund it, won't cost a farthing! That's
why we need visionaries like Al Gore, bold men
not afraid to take on the special interests, leading
by example.
I agree. What else is our government good for, if not to impress us
with all of it's wizardly expertise and can-do mindset.
The all electric car is technically doable, although having even a
small onboard ICE for the minimal cruising needs of sustaining 60+ mph
might represent a good compromise, especially if it's contributing
zero NOx and minimal CO2 at a hybrid usage of 200 empg per fossil fuel
usage.
The Electric Car / sci.electronics.design
http://groups.google.com/group/sci.electronics.design/browse_frm/thread/2bfee708dee351b9?
BradGuthwrote:
I suggest you find out the frontal area and drag coefficient of a Hummer, plus its
weight and rolling resistance.
If you had the ability to do the required 'sums' I'm sure you'll find that the power
required to propel it under a typical driving regime will never allow '100 mpg' or its
equivalent. Ditto for 200 mpg and the Volt.
Double ditto right back at you, as I've been there and done that. Of
course double-ditto-duh once again, as it's hybrid city or local
commute empg, and having replaced our mostly N2 atmosphere with that
robust fluid of h2o2, so that we obtain the most clean energy and best
amount of bang per gallon of whatever fossil or biofuel, is actually
accomplished within existing physics and doable technology.
I believe the mass ratio is something like roughly 7:1 up to 7.2:1 for
h2o2/c12h26 (hydrogen peroxide / kerosene or RP-1), a little better on
certain heavier fuel oils such as diesel No.2 and perhaps nearly as
good enough with plain old gasoline, and a bit worse off with certain
biofuels, though all dual fuel injected and 100% computer controlled
(of course), so that your little zero NOx engine for that hybrid
Hummer or GM Volt can safely mix and match to almost any combination
of fossil and biofuels as your heart desires.
http://www.dunnspace.com/alternate_ssto_propellants.htm
We're also talking about a fairly small radial turbine or some other
rotary efficient engine that's driving a direct coupled high speed
alternator. I suppose you've got those insurmountable problems with
that as well.
What's your sorry excuse for being such an all-knowing naysay stick in
the mud?
- Brad Guth -
ChairmanOfTheBored
- Brad Guth -
Let's just say that you are not providing us with any breakthrough,
startlingly "new" information, dumbass.
BradGuth
That is true, because those related laws of physics certainly haven't
changed, and there's not really any new and improved science from the
past few decades.
In other words, the h2o2 + whatever fuel combinations are still the
same, still capable of offering a zero NOx and minimal CO2 exhaust,
and still capable of getting 100 empg on behalf of that hybrid Hummer,
or 200 empg from that GM Volt. Just exactly like the clean energy
extracted from the sun, wind or whatever hydroelectrics including
tidal derived energy is still representing the same old clean and
renewable energy on behalf of delivering multiple teraWatts (as many
as you'd like), just as it was capable of accomplishing such as of
decades ago.
Sorry about all that.
- Brad Guth -
The Ghost In The Machine
In sci.physics, BradGuth
<[email protected]>
And already has been done, several times in fact. The main issue is
recharging the batteries.
usage.
The car is not contributing the NOx, but its power source might be.
This power source is most likely a coal-burning electric generation
plant.
As for 200 mpg...that's a little high.
that as well.
the mud?
- Brad Guth -
And the creation of H2O2 is done precisely how, again?
Clearly this is the fuel of the future (if one can deal
with the fact that it's highly explosive, but that's a
technical detail), but can neither be harvested from plants
nor extracted from minerals without some sort of process.
I'd like to know the details thereof, if you don't mind.
John Larkin
past few decades.
Conventional piston engines don't make obnoxious amounts of nitrogen
oxides. Seems to me that H2O2 is an awfully inefficient way to get
oxygen, when it's free for the asking all around us.
H2O2 is a damned expensive way to transport oxygen. And aluminum is a
damned expensive way to transport electricity.
decades ago.
Explain to us what is the relationship between H2O2 and all those
terawatts of clean, cheap energy. Since we're engineers, some numbers
would be appreciated.
Wild idea breakthroughs are a staple around here. The burden of proof
is on the presenter, to explain why it might work and then to explain
why it isn't already being done. Sorry, conspiracy theories are not
accepted.
John
Eeyore
BradGuth said:
See above, and comprehend. Or is that asking too much?
Where are your calculations ?
Any idiot can make unsupported claims. And you're certainly an IDIOT.
Graham
Eeyore
past few decades.
Where are the calculations ?
100 mpg Hummers are simply NOT possible.
Graham
MooseFET
At 15 MPH with tires so hard they ring, it is.
The main problem with the Hummer on the highway is that it is less
streamlined than a brick.
BradGuth
You folks still can't think inside or much less outside the box, can
you.
accepted.
I've posted such numbers dozens of times, and your PC or MAC can
otherwise search for and thus uncover all the fancy numbers you'd care
to review. However, from time to time I'll edit and thereby revise
upon a given application.
What is it about the clean and renewable 40 kw/m2 of a given tower
footprint of solar and wind derived energy do you not understand?
If not for the makings of h2o2 and aluminum, what else would you smart
folks do with a spare teraWatt of energy?
How else would you go about burning coal at it's peak efficiency
without water, at minimal CO2 and without causing NOx?
BTW, here's a wild idea breakthrough:
A piston engine of 4 cycles is about as mechanically inefficient of an
IC enigne as it gets, and the burning of a mostly N2 atmosphere is
every bit as dumbfounded physics on steroids as it gets, and the last
time I'd checked that's no conspiracy theory.
- Brad Guth -
U
Uncle Al
BradGuth wrote:
[snip]
usage.
[snip]
1) Thermodynamics.
2) Chemistry.
3) Idiot.
Dr. Schund proposes a pop bottle-sized 13.4 gigawatt electrical
generator - and Dr. Schund has numbers on his side, unlike Brad Guth.
http://www.mazepath.com/uncleal/htoo.htm
BradGuth
You've been off-world again, haven't you.
Which "The Ghost In The Machine" is it this time around?
What part of a 40 kw/m2 worth of tower footprint is way over your
head?
Haven't you ever heard of Warren Buffett, or physics?
If enough h2o2 is created via renewable energy that's every bit as
squeaky clean as solar, wind, tidal and geothermal, then where's all
the nasty pollution you speak of coming from?
BTW, you don't really recharge the h2o2/aluminum battery. It's more
like a fuel cell of stored energy, and actually lots of it per kg.
- Brad Guth -
John Larkin
OK, refresh my memory: if we convert aluminum oxide to metallic
aluminum by electrolytic smelting, and convert the aluminum back to
electricity in a Al-H2O2 battery, what's the net efficiency?
And for each KWH of delivered energy, how much H2O2 do we need, how
much did it cost, and how much energy did it take to make it?
Tower footprints can be arbitrarily small; it's what's hung on the top
of the tower that costs.
Energy is not measured in terawatts. And I'm not aware of any "spare"
power of terawatt magnitude. If we had terawatts of clean, cheap
"spare" power, why wouldn't we use it to power the electric grid,
saving a lot of coal and natural gas?
Piston engines haven't changes fundamentally in 100 years, despite
lots of challenges from turbines, Sterling monstrosities, various
weird rotary engines, steam, fuel cells, whatever. That's pretty
impressive. Still pistons, rings, cranks, cams, poppet valves, spark
plugs.
John
Eeyore
It has a drag area of about 2.5 sq metres. Its 3 1/2 tons results in a fair bit of rolling
resistance too.
I just calculated the power required to propel it @ 70 mph (the UK national speed limit) as
52kW. That means that 100 miles (at 70 mph) would require 52 x 3600 x 100/70 kJ = 267 MJ
Regular gasoline (per Wikipedia) contains 34.8MJ/litre. A US gallon therefore contains 132 MJ.
So it would only need a 200% efficient engine *** LOL *** to propel this Hummer at 100 mpg (at
70 mph).
Brad Gruth doesn't seem to understand the problems about ICE efficiency.
Graham
BradGuth
What does it matter, if the original resource of those electrons came
from a 100% renewable and squeaky clean resource?
Isn't 10% of something that's clean and renewable better off than 100%
of what's further pillaging, raping and polluting of mother Earth
that's anything but renewable?
It's within the regular laws of physics, and it's on the internet. Go
fish.
Again with all the associated "cost", as though the pillaging and
raping of mother Earth, plus the energy wars upon wars and continued
polluting are of no cost or future consequences.
What is it about spare/surplus clean energy that you do not
understand?
Perhaps you need to speak with wizard Willie Moo, or simply address
the 65,000 teraWatts of solar energy influx that's mostly (99.9999%)
going to waste, or that of the Earth/moon energy of 2e20 joules that's
equally 99.9999999% or greater ignored and/or wasted.
plugs.
Then god forbid, don't you folks dare change a damn thing, as there's
still ice to melt and our frail environment to trash according to your
original plan.
- Brad Guth -
Eeyore
No you haven't.
If you were SERIOUS you'd post them on a website instead of expecting people to search (for
stupidity and who wants to look for a lload of nonsense). Have you ANY IDEA how difficult it is
to trawl through old Usenet posts looking for a 'needle in a haystack' ?
In any case your 'numbers' must be wrong. It barely requires high-school grade maths to show
that your ideas are completely INSANE.
The most important fact is that H2O2 doesn't improve 'mpg'. In fact (taking the total energy
burden of manufacturing it) it degrades it.
Graham
Eeyore
Brad Gruth doesn't care about efficiency. In his world there will be limitless
FREE solar power to do this.
At which point of course he simply shows himself to be a clueless IDIOT.
Graham
Jim Thompson
[snip]
original plan.
- Brad Guth -
Naaaah! We only want to trash leftist weenie nutcases ;-)
...Jim Thompson
