The untouchable wire.
AJB2K3
Jun 26, 2004
185
Ive just got F**k*d off trying to tin a bit of 4 core ribbon cable and after 10 min trying i give up.
I cant get the stupid wires to tin.
has anyone else ever found this?
windoze killa
Mar 4, 2006
136
Are you using flux? What sort of solder are you using? Is the wire new or old? Does the wire have interleaved threads (Litz wire)?
Try cleaning the wire with Isopropyl Alcohol and use plenty of flux (NOT BAKERS FLUID). Use resin core solder and not plumbers solder.
Virus
Dec 18, 2005
98
AJB2K3
Toss it in file 13, and take another one, or use something else.  ??? ??? ???
Will only take
Mike11298
Apr 27, 2006
11
Tinning should be VERY simple - just make sure you are using pre-fluxed solder (or have flux).
MP1
Dec 7, 2003
3,397
I always use a small solder pot. Flux the wire end and dip. That is all there is to it. Nice clean shiny tinned wire every time.
MP
AJB2K3
Jun 26, 2004
185
Arg the problem may be flux after all. Im using maplins lead free solder and i dont think its got good flux in it.
Do maplins do pots of flux or is there someone else who does in the uk?
windoze killa
Mar 4, 2006
136
Personally I would never use lead free solder. It is crap and WILL cause fragile joints, I don't care what the manufacturers say. There is probably a reason why the defence forces around the world are exempt for RoHS of solder. Get some good old resin core solder and a small tin of resin flux.
gogo2520
Aug 14, 2005
495
hello
    I never had an luck with lead solder either. I suppose if that was all I did all day is solder i'd want it but for what I do i'll stick with the lead solder.
                                            gogo
