then what does jp1 and jp2 mean here?
saygn
Dec 10, 2018
3
Hello friends,I'll perform the final project for this card, but I don't know what's JP1 and JP2 displayed here.I'm using altium for schematic and PCB design.which component should I use and what does it do?thank you.
It means Jumper.
Pull those blue things off and you'll find 2 pins. Those blue blocks contain a bit of metal that joins the two pins together.
Typically it's for setting an option, but you'd have to look up the documentation to see what these are for. It *might* swap the transmit and receive pins, but it also may be for something totally different.
edit: I normally would recommend you start a new thread rather than reopening one from 7 years ago.
saygn
Dec 10, 2018
3
It means Jumper.
product description says 'Optional RTS and CTS handshaking functions'.Could it be for jumpers
It could be. It's definitely NOT for swapping the transmit/receive pins (and that only works for 3 wire connections - that this is not).
It's difficult to tell where the jumpers connect to, but I can see where they don't connect to :)
