I have seen where a signal can originate at the emitter of a transistor, or at the base. Assuming a base resistor, it seemed possible that the signal applied to the emitter would be larger at the base because of the base current and the resistor. And in fact there is a signal at the base, but it is smalller not larger. Scoff if you will, but it seems logical that the signal could be larger dependent on the base resistor.
It's hard to see, but if you plug in some numbers, here is what happens.
