USB protocol, couple of questions on low level stuff...
Brane2
I am plowing my way through available USB1/2 literature, but I still have a few holes on actual implementation.
1. if everything on USB has to be carefully timed, how does USB hub cope with the consequences of bit-stuffing as part of NRZI coding ?
I mean, when doing IN transaction, USB HUB can not know in advance how much bits will some packet actually have on wire as that will depend on how many bits did endpoint have to stuff-in.
And this means that USB hub can not know how much will data transfer take. Does this mean that USB hub has to assume worst case when planning transfers for frame/microframe or is some other mechanism employed ?
2. Is there any way to make transfer of unknown length ( up to maximal size) or does each transfer length have to be preset in enpoints config before transfer ?
Brane2
Errm, forget it. I found my answers.
HUB and driver have to take care of it by catering for worst case, which means that there can be significant dead times during communications.
Why was it designed this way I'll never know. It was supposed to be relatively simple interface, but it ended with more complications than PCIe. WTF ?
Had I designed it, I would never waste one wire pair just for power. I'd use both pairs for power and couple signal AC on top of that. And I would use at least 12V for power, if not much higher, say 24V or 48V.
And I'd drive pairs bidirectionally so that each receiver would have to subtract signal of its transmitter to get Rx. And I'd drop NRZI in favour of 8b/10b or something like that.
This, as it is now ( as of V2.0) looks like piece of crap that caught cancer.
josephkk
HUB and driver have to take care of it by catering for worst case, whichmeans that there can be significant dead times during communications.
Well for starters USB 1.0 foolishly incorporated many bad properties from
HP-IL and ADB from which it inherited (partially derived). For backwards
compatibility both USB 2.0 and 2.1 retained them. USB 3.0 got rid of only
the worst, creating a legacy comparability issue where some USB 1.0
equipment is not interoperable.
Had I designed it, I would never waste one wire pair just for power. I'duse both pairs for power and couple signal AC on top of that. And I would use at least 12V for power, if not much higher, say 24V or 48V.
And I'd drive pairs bidirectionally so that each receiver would have to subtract signal of its transmitter to get Rx. And I'd drop NRZI in favourof 8b/10b or something like that.
Gosh you seem a bit new to evolving standards.
