What does Complementary Means?
Shahriar
Mar 18, 2004
451
Hi
In Transistor datasheet there is alays a word “Complementary”. For example TIP42 is TIP41 Complement. What does this mean?
ThanX
Shahriar
2old4digital
Here is a possible answer ;  The inverse or opposite of a number used in Logic devices, so the second # is the opposite of the first # a  1  becomes 0 or high become low, or A becomes  (not) A. Or in this case it, could mean that eather or will work in each others place, so if you have both check the resistance of both.
ECET0purdue
Jan 29, 2005
314
- Strawberries and cream complement each other perfectly.
maybe they go good together...or they tast good?
audioguru2
Apr 6, 2004
12,026
An audio power amplifier needs a push-pull output stage. It can use two identical NPN transistors or a complimentary pair with an NPN for one transistor and a PNP transistor for the other. An NPN is complimentary to the PNP. ;D
Alun
This applies to MOSFETs too; CMOS ICs have a complementary pair on the output.
Shahriar
Mar 18, 2004
451
ThanX all
Dear Audioguru
Obviously, NPN is a complimentary of PNP. But when it is mentioned that TIP41 is Complementary of TOP42, I think it means to using these two together is better. But what Parameters makes TIP42 suitable to use it with TIP41?
ThanX
Shahriar
Alun
The TIP42 is a complement to the TIP41 because it has the same characteristics except for the fact that it's a PNP transistor.
