What is this component ??
vick5821
Jan 22, 2012
700
Hey all, what do you this component will be ??
My rice cooker can't function and after using test pen to test the component i found tat this component didnt pass electricity. What is this component ??
The words on it write
SHENG PING TF184 oC
10A 250V RY
14,478
Hi vic
havent seen youfor a while, happy new year :)
Agreed, a 184 Deg C thermal fuse
DAve
These things contain a low melting point metal that forms the circuit inside. When they heat to the melting point, the metal melts and the fuse opens.
Then you but another one.
shrtrnd
Jan 15, 2010
3,903
Yeah, it's a thermal fuse. You should be able to cross the numbers on it to
the correct amperage.
Each manufacturer also used the colored goop to seal it, to designate the amperage
for their product line.
Buy two if you use you're rice cooker regularly. I blow mine about once a year.
duke37
Jan 9, 2011
5,364
And do not ruin the new fuse when installing it. If it is soldered, use a heat shunt.
