Can someone inform me how to connect an Enforcer retro-reflective photoelectric beam sensor to a siren. The sensor has 5 wires of the following colors : brown, blue in the multi-voltage circuit ( 24-240 VAC or 12-240 VCD, polarity not important) and a gray (NC), white (Com), black (NO) in the Relay Output. I don't understand electronic diagrams so I would appreciate if you could inform me how to wire by cable color. Ex: The brown cable with the hot wire, the blue with ...... I have tried different combinations without success. Also, can you tell me if when the beam is activated will the siren keep activated or will it stop when the beam returns to normal after the object that interrupted the beam is removed? If so, can a shut of 60 seconds 8 pin timer be installed? How would I wire it?
