Wire
SparkyCal
Mar 11, 2020
863
Can anyone recommend what type of wire to use for wiring components using solder on a circuit board. As you know, some wiring is very tight and delicate, so I am looking for something that is very thin and easy to use.
Thank you. I plan to order it from Amazon
bertus
3,852
Amazon has a lot to offer:
https://www.amazon.com/s?k=solid+hook+up+wire+kit&rh=p_n_condition-type:6461716011,p_72:2661618011&dc&qid=1588844878&refresh=1&rnid=2528832011&swrs=9940E9DC72EA541138B1152B0B52EA0C&ref=sr_nr_p_89_5
When you take a kit, you will have several colors, so you can take different colors for power and signal.
Adafruit has also a box:
https://www.adafruit.com/product/1311
For cutting the wires, I use something like this:
https://www.adafruit.com/product/152
Or you could even go for a complete tool kit including Breadboard, Cutter, Desoldering Tool, Holder, Multimeter, Plier, Power Pack, Soldering Iron, Solder, Vise, Wire Stripper :
https://www.digikey.com/products/en?mpart=136&v=1528
Bertus
  • Adafruit tool kit.pdf
14,293
For direct wiring on a protoboard I use magnet wire. The insulating lacquer is easily removed on the end of the wire with a hot soldering iron whereas crossing wires are separated by double insulation.
If you want to use colored insulated wire as suggested by @bertus m take care to use solid wire, not the stranded type. Stranded wire requires you to twist each end and to be careful when inserting a wire end into a via to avoid single strands to stand off and possibly create a short circuit. Can't happen with magnet wire.
KMoffett
Jan 21, 2009
723
If it is for point to point on a donut pad perfboards, I'd use 30ga wire wrap wire. Easy to use either insulated or stripped. If you go this way, get a good stripper that works down to 30ga. Several colors are nice but not really necessary. I do almost all my prototypes this way.
WHONOES
May 20, 2017
1,242
I agree with Harald. I have recommended magnet wire before. If you can get the type that has solder through insulation, it makes the job a lot easier. I've been using it for many years.
SparkyCal
Mar 11, 2020
863
Thanks. I think I will get an assorted kit for future uses, but I am intetrested in what has been said about magnet wire. What does solder through insulation mean? and how does it make the job easier?
Thank-you to all
by the way, I am located in Canada, Usually I can get many products via Amazon. But there are a few sites outside of Amazon that do not ship to Canada.
SparkyCal
Mar 11, 2020
863
Thanks. So in practical terms, when I solder one end of the wire, it should solder fairly easily, but the remaining part of the wire will remain insulated?
Forget this question. It was answered with the link you provided. Should have read that first.
dave9
Mar 5, 2017
1,191
I don't use wire on perfboard much but when I do, I usually use solid network cable wire because I have salvaged a lot of it. Of course it is going to oxidize long term and the gauge can't carry much current but neither if these things bother me much if doing a quick 'n dirty perfboard build.
One nice thing about it is that the insulation (polypropylene? not sure but it isn't vinyl based) seems to do a better job than some at keeping oxygen out, it is very bright/clean copper compared to some other wire types, takes solder very readily.
SparkyCal
Mar 11, 2020
863
Hi folks. I received my amazon order for enamelled wire. I bought a role of it, I think it is 28 gauge. It is blood red in. color, making it easy to see. I wish i would have known about this long ago. It makes connecting things so much easier and minimizes the chance of shorts.
The only annoyance, is stripping the ends to make the connections. Any advice? I know the link suggests using a blob of solder, but I found that a little cumbersome. I am using a knife that I put pressure on, while the wire is on a flat surface. is there an easier way, or a special tool?
duke37
Jan 9, 2011
5,364
I sometimes use a folded piece of emery paper. Old wire can have the insulation removed with a candle flame.
You can get solderable wire where the insulation is removed by the hot solder. This is almost mandatory with small diameter wires.
WHONOES
May 20, 2017
1,242
You need to get the soldering iron very hot, I run mine at 400degC, then the insulation assuming you have the correct type, will burn off quite quickly. A little practice may be beneficial.
Note: Not all magnet wire has insulation that you can solder through.
