315Mhz RF Remote Transmitter – Arduino Compatible
- Rajkumar Sharma
- 794 Views
- easy
- Tested
- SKU: EL113489
- Quote Now
This is a two-channel RF Transmitter unit that consists of, Atmega328 microcontroller, 2 Tactile switches with pull-down resistors, a programming port, and a 315Mhz RF transmitter module. It is an Arduino compatible open-source project that can be used for many RF transmitter applications. It is advisable to use 1 Foot hook-up wire as Antenna to enjoy a maximum range of the transmitter.
Arduino Pins: D3, D4 Tactile Switch and D12 data out for AM transmitter
- Supply 5V DC @ 20mA
- 2 Tactile Switches with Pulldown Resistors
- PCB Dimensions 52.71 x 28.26mm
Applications
RF Remote ON/OFF AC or DC loads like, Fans, Lights, Home Appliances, Door control. This transmitter is compatible with 315Mhz RF Remote Receiver with On-Board Relay.
Arduino Code
Arduino Code is provided as a download The code works with single SW1, it toggles the Receiver Relay when the switch is pressed. A new Atmega328 chip requires Bootloader and Arduino firmware programming. Please, check the link below to learn more about programming the new Atmega328. Transmitter PCB has an onboard programming port.
https://www.arduino.cc/en/Tutorial/BuiltInExamples/ArduinoToBreadboard
FS1000A Receiver Module Specs
- Transmitter Model: FS1000A
- Transmitting Frequency: 433.92MHz, 315MHz, 330MHz
- Operating Voltage: 3V to 12V
- Transmitting Power: 10mW to 40mW 16dBm
- Transmitting Range: 20 to 100 meters through walls & 500 meters max in open area
- Data Transfer Rate: <10 Kilo Bytes Per Second (Range drops above 2400 bytes per second)
- Modulation Type: OOK
- Current Consumption: 20 to 28mA
- Current Consumption in Standby: 0mA
more information: https://www.componentsinfo.com/fs1000a-433mhz-rf-transmitter-xy-mk-5v-receiver-module-explanation-pinout/
Schematic
Parts List
NO. | QNTY. | REF. | DESC. | MANUFACTURER | SUPPLIER | SUPPLIER PART NO |
1 | 1 | CN1 | 8 PIN MALE HEADER PITCH 2.54MM | WURTH | DIGIKEY | 732-5321-ND |
2 | 1 | CN2 | 2 PIN MALE HEADER PITCH 2.54MM | WURTH | DIGIKEY | 732-5315-ND |
3 | 1 | C1 | 10uF/16V SMD 1206 OR 1210 | MURATA/YAGEO | DIGIKEY | |
4 | 2 | C2,C3 | 0.1uF/50V SMD SIZE 0805 | MURATA/YAGEO | DIGIKEY | |
5 | 2 | C4,C5 | 22PF/50V SMD SIZE 0805 | MURATA/YAGEO | DIGIKEY | |
6 | 1 | D1 | LED SMD SIZE 0805 | OSRAM | DIGIKEY | 475-1278-1-ND |
7 | 1 | E1 | ANTENNA | 1 FEET HOOKUP WIRE | ||
8 | 2 | M1,M2 | RF AM TX MODULE | ALIEXPRESS | ALIEXPRESS | FS1000A ALIEXPRESS |
9 | 3 | R1,R2,R3 | 10K 5% SMD SIZE 0805 | MURATA/YAGEO | DIGIKEY | |
10 | 1 | R4 | 1K 5% SMD SIZE 0805 | MURATA/YAGEO | DIGIKEY | |
11 | 1 | R5 | 1M 5% SMD SIZE 0805 | MURATA/YAGEO | DIGIKEY | |
12 | 2 | SW1,SW2 | TACTILE SWITCH | C&K | DIGIKEY | CKN9085CT-ND |
13 | 1 | U1 | ATMEGA328TQPF-32 | MICROCHIP | DIGIKEY | ATMEGA328PB-AURCT-ND |
14 | 1 | X1 | 16Mhz | ECS INC | DIGIKEY | X1103-ND |
Connections
Gerber View
Photos
good work done
