Jump to content
Electronics-Lab.com Community
what is silk screen??
fatoota
Many of the older PC Board shops used silk screen to make the circuit pattern on the copper as well. I tried this, but it takes a lot of practice and I never liked the results as compared to the photography method. It is also very messy. You have a lot of clean up after each board you print.
Have you considered Iron on transfer or photo etch methods?
MP
Link to comment
Share on other sites
No alcohol does not affect it. I dont know if you use a strong one what happens.
I usually spray both sides (copper side and component side) with PLASTIK from Cramolin. (insulating spray) but you dont have to do it. It Wont Leave.
When I spray it I dont touch the silkscreen because the letters come off with the spray, (It has a little more alcohol...) but when it dries it leaves a nice and shiny finish
Link to comment
Guest Kasamiko
The previous is with HP photo paper.
This one is with plain paper.
This topic has been discussed many times in this forum but as far as I can remember your the first to confirm good result using ORDINARY PAPERS.. :o to print the parts placement guide.
Can you please post here your techniques on how you did it??
BR
Rhonn ;) ;)
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
