Jump to content
Electronics-Lab.com Community
I need some ideas on a battery back-up circuit that will work once a particular circuit is activated. The main power supply will be functional, but the back up ckt. will work only when the activated signal is received and the main power supply is interrupted. If the ckt. is not activated and the main power supply is interrrupted, the back-up is deactivated.
Han
Link to post
Share on other sites
Thanks for the responses.
I am designing an alarm using AC input and 5VDC output from the power supply. The alarm will be activated by a non-contact input/signal. When activated, if shaken or AC removed an alarm will sound. In the deactivated mode the alarm does not sound.
I need to design a battery back-up that will allow the alarm to sound once the AC is interrupted in the activated state. I have designed a ckt. using gates, relays and transistor but I need to see other ideas of how to do a batt. back-up for the ckt.
Thanks. I hope I provided enough info.
Thanks again
Han
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
