Jump to content
Electronics-Lab.com Community
Floating Computer
Guest Yevgenip
Guest Yevgenip
Hi.
I want to make my computer look like it is floating by putting some Ultrabright LEDs under it (Like in those fancy cars).
I figured I'll use the transformer fan output which is 12 V as a power supply, pass it through a voltage devider and then connect the LEDs in parallel.
The LEDs work on 3.5 Volts and 20 mA.
Two Questions:
1) Will my design work? have a better design?
2) What is the maximum ouput power my fan output can produce? /or/ What do I do if I don't want to burn my PSU?
Thanks.
Link to comment
Share on other sites
Guest Yevgenip
Thanks, Ante. 8)
I know how to calculate the resistance I need to get the needed current and voltage drop. Do you mean to connect a resistor to each LED or a really big one before the parallel junction? Did you mean a different calculation?
Thanks.
Link to comment
Guest Yevgenip
Oh and another thing:
What kind of fuse would you recommend? How do I calculate the amps of the fuse? where to put it (On the circuit that is)?
Sorry for all the basic question, I realy don't want to screw it up and plus: You are an electronics theory expert god 8), and I'm just hopping to a Jr. theorist. :'( ;D
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
